2226B Bias Adjust
LBPete
Rolling Along
Can anyone give me the spec for bias current on a 2226B? Also, here's a picture of the amp board can anyone ID the bias and offset trimmers for each channel? Thanks.
- Pete
I don't have one. Have you tried to find one? I am sure that you have, but they must be scarce if no one has one.
Jim, the thing works perfectly. I hate to buy a service manual just to set the bias and offset.
- Pete.
- Pete
Hi Pete,
I hope this help,
If you need more info, just let me know, I'll scan the full SM tomorrow at work.
Tony
Thanks Tony. This looks like what I need. I'll let you know how it works out.
- Pete
Tony, that was just the information needed. The bias and offset came right into spec. Thanks for the post.
- Pete
I bought a 2226 last night. Would the same apply to it as the 2226B, as far as
the three voltage checks and adjustments above?
I don't know what changed with the B version. Take a look at the picture of the amp board in the first post. Does the amp board in the 2226 look that that one? If so, it's a good bet the procedure is the same.
- Pete
