Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Infinity Loudspeakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 04-14-2007, 04:38 AM
jpb_dk jpb_dk is offline
AK Member
EMIT-R, Tweeter. How to repair
Having nearly the same problem as described for the traditional EMIT.
I cant resolder the terminals on the EMIT-R folio. Picture attached.
While remelting the solder i cant make it "bite" again. Do anyone of you know about cleaning the joint so that the solder can "bite" like normal ?
It seems that the flus in the new solder is not enough.
Im affraid to turn up the heat to much on my soldering station and "roast" the diaphragms itself.
Ideas are much appriciated. It seems to be "cold soldering" from the beginning, and to resold the other tweeter would be a good thing to do in the same operation.
Thanks
Jens
  #2
Old 04-14-2007, 07:05 AM
jeffn's Avatar
jeffn jeffn is offline
Mid-Fi Crisis
Just an amateur comment, but melting the solder and thinking it will stick to something that not as hot is a big mistake.. Remember, you need to heat the connection first then touch the solder onto it.
__________________
32░56'49.15"S
151░39'43.78"E
In the middle of my Street
  #3
Old 04-14-2007, 10:41 AM
Jygesq Jygesq is offline
AK Member
use a low wattage pencil solder iron
about 20 watts with thin rosin core solder. heat contact up till its hot enough to melt solder when it touches it. low wattage iron is key
__________________
Infinity RSII. Yamaha CX2. Acurus A250, Marantz SA11. Yamaha px-3, with Grace F9E. , Yamaha tx-950 . RETIRED: Yamaha cr-1020, AR Receiver,Scott 340,340b 222c,310 tuner, ADS 810.AR 3A ,KLH6,AR TT Marantz 63se, Advent 201A
  #4
Old 04-14-2007, 11:34 PM
AK Member
Jygesq & jeffn, thanks for your comments.
Its more like the diaphragm is coated.
The solder and the wire/terminals goes well.
  #5
Old 04-16-2007, 02:44 PM
AK Member
ok, problem solved. Do not try to solder it. It has to be done with conductive "silver-glue". Another problem is that the previus owner have "roasted" the tweeter with his CervinWega monsterWatt amp. It has to be changed because of diffrence in weight of the diaphragm (responcetime, freq-resp ect.)
Anyway. I picked the Kappa 7,1 up for $120 and have to fix a tweeter. Not that that bad at all. Next step is to turn them into an active speaker with 2x hypex 180W amps, electronic x-over to replace the bas-section HF filter, and the top section LF filter. Components in the passive part really sucks. That should be done over a weekend.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Meistertech Solutions
Capacitor World
AudioFriends
Analog Engineering Associates
Vintage Home Audio
Okki Nokki
Hudson Valley Hi Fi
Wargos Electronics
Organ Donor Parts
Parts Connexion
Sound Stage Direct
Take Five Audio
Audience AV
Howard Products
Simply Speakers
The Tube Store
FM DX Antenna
AudioClassics
Many Moons Audio
Audio Doctor
RSL Speakers
Yesterday's Audio
DeWick Repairs
BOI Audio Works
Politicalchat.org
MCM Electronics
Amplifiedparts
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
