Turbokeu
Member
In replacement of my 'old' (at most one hour of operation!) Technics SL-QD22 TT from the late 80's I scored a second hand Technics Direct Drive SL-1700 MK2 from 1980 on ebay:
The SL-1700 MK2 (weight 12kg!) is the semiprofessional version of the famous SL-1200 MK2 TT with the same strong motor with quartz PLL-drive and the same arm mechanism.
The complete mechanism (drive platter and arm) is suspension mounted (the SL-1200 has a fixed mounting), and the arm mechanism is semi-automatic (the SL-1200 is completely manual).
The SL-1700 MK2 is esthetically in quite good condition (some scratches on the housing and the plexi cover), most of the buttons need a Deoxit treatment.
The semi-automatic operation originally didn't work anymore, but some googling teached me that the cause is a defectuous cueing belt on the arm/lift mechanism.
This belt is the weak point of the SL-1700, after 27 years it's more than logical that the rubber has worn out.
In the meanwhile I replaced this belt by a little rubber band till I find an original cueing belt.
Finally I will be able to replace the included Stanton 500 cartridge (the SL-QD22 has a fixed Audio Technica cartridge) by a beautiful Ortofon Concorde Pro set that I have laying around for years now:
Nonetheless I have some troubles setting the arm balance and weight (I don't have the owner/operation manual).
My question: Does anyone owns/has a SL-1700 MK2 manual?
Only a torough cleaning, and a cover polishing left, and enjoy my old records...
Happy CD
Happy CD
