dr*audio
Fish fingers and custard!
When you overhaul a 9090dB, there are a few areas that so far I have found it difficult to access; the board with the speaker relay on it, and the regulated power supply board. I have discovered a trick to get to these areas very easily and will share this info here.
The assembly on top, containing the tuner, IF board, display, and regulated power supply, comes off in one piece. You remove the front panel, remove 8 screws from the top assembly, and you can flip it back out of the way. Then you can access these boards. Once you do this, the following things need to be done for every 9090dB:
1. Resolder the joints on the regulated power supply.
2. Tighten the ground screws on the IF Board.
3. Replace the speaker relay. Do NOT try to clean the contacts, it will only work for a short time.
4. In this receiver, the speaker jacks are shorted to ground when the relay turns off. Sometimes the relay contacts weld themselves shut and short the poweramp output to ground when the relay turns on. Remove the jumper wire on the relay board that goes from the relay contacts to ground. It is just to the right of the relay, right next to it.
