Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Tube Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 07-11-2007, 11:48 AM
bOUddha's Avatar
bOUddha bOUddha is offline
Shouty and lovin' it!
Substitute for 6N1? 6922 mebbe?
Will that work or not. My tube-subs book doesn't list 6N1 at all, so I'm at a loss here.
TIA.
__________________
Sumiko Blackbird, RB-300 w/TechnoWeight, Sota Sapphire, , MHZS CD33E, ARC PH-3, Yaqin MS300C, Altec 802D-416Z in 612 cabinet
  #2
Old 07-11-2007, 01:32 PM
Bob E.'s Avatar
Bob E. Bob E. is offline
AK Member
What is a 6N1? Are you sure about that number? Or is this one of those screwy Russian numbers?
--Bob
  #3
Old 07-11-2007, 01:58 PM
bOUddha's Avatar
6N1P-EB is the only one I've found so far, and he says it's a direct replacement for E88CC or 6922.
I guess we'll find out, huh?
__________________
  #4
Old 07-11-2007, 02:06 PM
sleddogman's Avatar
sleddogman sleddogman is offline
AK Member
I believe the heater voltage is higher on the Russian 6N1P (or 6N1Pi as they're called because the Russian letter for P looks like the Greek symbol for Pi and a Russian N looks like an H) than the 6DJ8/6922/7308 versions. Be sure your circuit can handle it.
__________________
Member of the AudioKarma Pony Express®
  #5
Old 07-11-2007, 06:07 PM
bOUddha's Avatar
sleddogman-
The swap will amount to taking the 6N1Ps out of a Yaoin integrated and replacing them with the 6922s. What I'll have then is high heater current with the lower current tubes. To my limited experience and knowledge, the 6922s are the items under the strain, not the amp...yes?
__________________
Audiokarma
  #6
Old 07-11-2007, 07:11 PM
PakProtector's Avatar
PakProtector PakProtector is offline
AK member
hey-Hey!!!,
The 6N1P takes more current than a 6DJ8/6922. Voltage is the same at 6.3V. If your circuit is able to run the 6N1 it will probably provide a slightly higher voltage to the 6922's. Nothing I'd worry about much, unless the 6N1's started out high in the first place. 6.1-6.5 volts is what I'd be comfortable with.
cheers,
Douglas
__________________
1990 D250, NV5600, Luk 05-101, 16cm housing, TST Kit KDP tab, Powr-Lok'd 3.07, HX35...IC soon
She wasn't built to travel at the speed a rumour flies
  #7
Old 07-11-2007, 07:21 PM
bOUddha's Avatar
Thanks, pak. I got a supply of both, with the higher quality going toward the 6922s. If the Russians prove any better than the oems, I'll save the 6922s for the pre-amp. If there's a problem, then I'll risk a somewhat shorter lifespan with the 6922 on the higher current, mmmkay?
__________________
  #8
Old 03-31-2008, 01:08 PM
dinga dinga is offline
AK Member
I replaced two of 6N1s from Yaqin MC-10L with RCA 6922s about 6 months ago. It still works. The sound is more refined.
  #9
Old 03-31-2008, 07:40 PM
socioloco's Avatar
socioloco socioloco is offline
Freakapottamus
Great!
I've got a flea amp called Itube that uses a pair of those rare 6N1. I'll get some 6922 to try...
Should I check things like voltage before installing those???
Do you think that there it's some risk to blow them (or the house) away?
Quote:
__________________
Trust your ears !!!
  #10
Old 03-31-2008, 08:41 PM
cableguy's Avatar
cableguy cableguy is offline
In Twang We Trust
http://www.audiokarma.org/forums/sho...d.php?t=153908
here are a few recommendations in this thread, including some Russian equivalents that I am using right now with great success.....
bOUdda, what are you using these tubes in?....
Bill
__________________
Bill
“One day I will find the right words, and they will be simple.”
― Jack Kerouac, Dharma Bums
Audiokarma
  #11
Old 03-31-2008, 11:20 PM
AK Member
I also tried Russian made 6N1P. On my Yaqin MC10L it produced a little bit more gain and brighter sound with two 6N1Ps. But when I used all four of 6N1Ps, there was a little bit more hum on my speakers and some noise on the tubes.
I used a pair of 6N1Ps for a while. Then, one of my tube friends told me that 6922 (or E8cc) has pretty much the same signal level as with 6N1 or 6N1P. I tried 2 RCA 6922s and it produced better sound than 6N1Ps. I was told that Phillips 6922 would also work good. I've had a pair RCA 6922s on my Yaqin for over 6 months and there had been no problem.
  #12
Old 04-01-2008, 07:26 AM
Frihed89 Frihed89 is offline
AK Member
The Russian 6n23P is a direct substitute for the 6922 and vice-versa, It is the parent tube of the EH 6922. Having said that, the EH6922 and the 6n23P bias quite a bit differently than many other 6922s.
  #13
Old 04-01-2008, 08:54 AM
bOUddha's Avatar
cableguy-
I've got four RCA 7313s in the back row, and the Russians up front...had them there since starting this thread. I put the RCAs in about three months ago, and I'm not interested in changing any of these tubes! I read that other thread and concur completely with your findings...
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Meistertech Solutions
Capacitor World
AudioFriends
Analog Engineering Associates
Vintage Home Audio
Okki Nokki
Hudson Valley Hi Fi
Wargos Electronics
Organ Donor Parts
Parts Connexion
Sound Stage Direct
Take Five Audio
Audience AV
Howard Products
Simply Speakers
The Tube Store
FM DX Antenna
AudioClassics
Many Moons Audio
Audio Doctor
RSL Speakers
Yesterday's Audio
DeWick Repairs
BOI Audio Works
Politicalchat.org
MCM Electronics
Amplifiedparts
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
