Utah Celesta - Could this be the Coolest vintage driver ever?
Redboy
a few good watts
I have no idea whether these will sound good, but when I saw them I had to have them. I mean, look at these things!
Anyone have any specs for them? What kind/ size of enclosure would be appropriate?
I did test them before buying, and didn't hear any glaring issues. Hard to judge the sound quality without an enclosure, though.
I had some later (early 70's) model Celestas and they were quite nice, not Tannoys or anything, but nice. And very cool.:smoke:
I guess I'd trade these for some Tannoys, if someone twisted my arm a little...
Open baffle? Then you wouldn't have to hide those baskets away completely.
I have tried to locate the T/S for those in the past. Couldn't find them but they have to be out there somewhere.
Might be a good open baffle candidate. Yes?
RC
Yeah, though I would have guessed they were manufactured in... Utah?
I don't know why I would have guessed that. :scratch2:
An Alternate Opinion From A Former Owner...
...At the beginning of my ongoing audio adventure I ran across these things in an Allied Radio catalog and had to have them because they looked so cool. The catalog description and specs were also impressive. I purchased a pair and built ported boxes per Utah's recommendations. Short story: they were the worst sounding speakers I've ever heard. A very coloured nasal/honky cardboardy sound that was extremely fatiguing to even my novice ears. No high end either. This experience soured me on home brew speakers for probably a decade. I don't think you'll like them but who knows.
Apart from their crappy sound there are some design issues that limit applications: 1. The frame design effectively prevents front mounting. 2. The cloth surround was (is?) very limp which probably rules out open baffle apps unless you add an HP filter. 3. Although the frame is visually appealing, you won't see it in a proper box so ultimately it's for naught.
Bottom line based on my experience is that these speakers are sonically unredeemable. Either keep them for static display or flip as fast as you can and don't look back. If they were mine they wouldn't be for long.
Well, that's a stinker! I wonder if I can justify keeping them for aesthetic reasons alone. I'll have to listen to them first, though. Maybe yours were just duds, Steve. Both of them... yeah, sure. :no:
Mount them in a clear Plexiglass box, like those old display speakers in the hi-fi shops. Mount a Heil AMT on top of it, and add another driver or two - midrange and a woofer - as well. The other drivers don't have to look spectacular, just nice enough. Make the other speakers functional, and you'll get great sound from them, but can still ogle the cool-looking Celestas, which will simply act as passive radiators. Probably won't suck too badly at that function! :D If you add dummy wires going to the crossover, most people will never notice that the Celestas aren't actually playing.
You could even mount the Celestas inside a large clear plastic tube that juts into the box (like a port tube), so they would sculpturally "hang in space" inside it. If the tube ran all the way through the box instead of just jutting into it, it would create isolation, taking the Celestas out of the sonic picture entirely, but making it seem as if they were an integral and high-tech part of the design. If you are really good with plastic, you could flare the ends of the tube and join them seamlessly with the box, reflecting the curve of the back of the Celestas. Such a design would LOOK really impressive, regardless of how it sounded, and as I mentioned above, adding other good drivers (to actually make it sound good) would fix that issue, too.
Great sound, neat looks! Just a little "cheating" involved. :D
They are nice looking, but are nothing special sonically (I think I may be being charitable).
Yes, they're high Qts drivers and they'd work on open baffles. At least those are the coax versions, not the twincones.
Now, there are plenty to debate, but I think 'coolest vintage driver ever' would be one of this coax's family.
I had a pair of those that I used in a High School wood shop project. They looked better/cooler than they sounded. IMHO
Wow those Utah Celesta speakers are cool looking. But I have to agree with MRH on the Altec 604 duplex speakers being the coolest. :smoke::smoke::smoke:
I'm not familiar at all with the Utah line, but those might work as a LF driver in a 3-way system with the aforementioned cabinets. They might be worth hanging on to. They certainly get my vote as "Tré cool looking speaker"!
At first glance, I'd say the Utah wouldn't be a good options for open baffle because of the width of the basket. Very good dipoles/open baffle speakers usually require very open baskets to avoid noise.
