#1
Denon Receiver shuts off ????
My 15 year old Denon receiver is losing sound shortly after turning on. When I turn it on, I hear the relay click and it will play for several minutes. Then no sound. If I turn it off for a minute and then turn it back on, it will play for a few seconds/ minutes then No sound. Any help is appreciated. Thanks
#2
I wouldn't continue to use it. It needs to be repaired.
#3
I figured that much at least. Any technicians have any suggestions? Could it be a simple DIY ?
#4
Hang in there...there are some very sharp folks who will hopefully chime in with usable suggestions for a fix....
Bill
__________________
Bill “One day I will find the right words, and they will be simple.” ― Jack Kerouac, Dharma Bums |
#5
I had a friend bring me a Technics that did that. After a few minutes to play it would say OVERLOAD on the display and shut off.
Turned out to be a single strand of speaker wire about 1/4" long had broken off inside the spring clip terminals and was shorting +ve and -ve. |
| Audiokarma |
#7
Quote:
#8
I had an Onkyo receiver that would do that. Traced it to a bad solder joint on a 2w resistor in the power supply. It would run quite hot, and I suppose over time it cracked the solder joint from the heat/cool cycle. I resoldered it and it worked fine after that.
__________________
Avatar photo taken Dec of 1968. Heathkit Compact Stereo. On the turntable is Best of the Beach Boys (either Vol. 1 or Vol. 2). |
| Thread Tools | |
| Display Modes | |
