Arkay
Lunatic Member
Since I've started renovating my AR-4x speakers, I've been reading around a bit about them, online. Ran across this, regarding the 3as:
http://murphyblaster.com/content.php?f=AR3a.html
Not the same model, but parallels can be drawn for most of these old speakers (other ARs, Advents, whatever...), and this has me thinking... these speakers, by all accounts, sound great. Out of respect for them as "audio history", I'm inclined to restore them to near-original state, first, but that "urge to improve" never entirely disappears. Several thoughts/questions result:
(1) He mentions the crossovers and the the severe cancellation in the mid-highs and the hump near the top of the woofers range. In a case like this, would "modern technology" give us a means to improve on the crossover and get a flatter response, or would this come at the expense of the sound? Are these speakers BETTER sounding for having these dips/humps, perhaps because they offset particular characteristics of the drivers, OR are they good IN SPITE OF these irregularities, and thus subject to improvement?
(2) There has been mention here recently of how good Advents sound after re-capping with recycled old oil filled capacitors (1000V). There was mention in the thread of some superior characteristics of oil-filled caps, too. Would this be a good/wise replacement choice in other/all speakers? I'm seriously considering getting them to try in my 2axs, which will be next up for a re-cap. If oil-filled caps are really that good in this application, why hasn't there been more mention of them in the past?
(3) He mentions no consideration having been given to driver placement. Assuming one kept box type (sealed, ported, etc...) and dislacement volume constant, would the sonic improvement from a more scientifically-determined driver placement be worth the effort of new box construction? I'm thinking of narrower front baffle for the tweeters, set back from the woofer enough so as to be time-aligned. Worth the hassle?
Another reason (besides restoring the ARs) that I'm considering these issues is that I found a home-made pair of speakers made with a TEAC midrange and crossover, mated with JVC SX-series woofer and tweeter. Someone apparently decided that a great 2-way would sound better if converted to a 3-way using a mediocre midrange. :headscrat The woofer and tweeter are seriously good drivers (tweets look very similar to those on Dynacos and Advents, with metal grills over them) from originally 2-way speakers. I know that is what they are because I look at them (SX-3 IIIs) and listen to them daily in my home office.
[The woofers have an 8" cone mounted in 11" surrounds, 12" with grill, quite unmistakeable!] Since the homemade cases on the ones I found are cruddy (crudely built raw plywood), I could just pull the drivers and try to "improve" the sound of the original speakers, without having to sacrifice a vintage pair to make the experiment.
Just musing aloud here... any comments/suggestions from the more experienced DIY speaker guys here?
