Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Pioneer Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 08-06-2007, 01:17 PM
Chip - HP Chip - HP is offline
AK Member
Question Pioneer SX-2500 Receiver ...
This morning I picked up (and it was heavy ) a Pioneer SX-2500 receiver manufactured in May, 1971 according to the SN (RE 19944) ... cosmetically, it's in great shape ... stylistically, it's not as pleasing as the silver faced Pioneer receivers ... per other threads, the power is 72 wpc ...
The bad news ... the wired tuning remote and the speaker plugs are missing ...
It has two Phono connections ... one marked MC/MM ... and the second has 2 pairs of female RCA connections ... one marked MM (which has black tipped plugs protecting the connections) ... and the other marked Cer ... does Cer stand for ceramic? ... what do MC and MM stand for? ...
There is also a switch titled PRE & MAIN ... and the choices are ... Separated ... and Inter-coupled ... to the right are pairs of female RCA connectors for the PRE OUT and MAIN IN ... w/o the the silver "U" connectors that one normally sees ... I am guessing that I should have the switch on Inter-coupled for normal use ... if that's right, why would I want to switch it to Separated ? ...
Apparently, this receiver was reviewed in the Oct. '71 issue of Stereo Review ...
  #2
Old 08-06-2007, 02:57 PM
KingBubba's Avatar
KingBubba KingBubba is offline
"Too Much Stuff"
Nice find, I have the little brother, the SX-990. It is pure Pioneer. You may not have noticed but the tone controls are split into left and right. The tuner should be very sensitive. The pre out and amp in can be used in different ways. You can put a processor (EQ) into that loop, or you can split your output to two amps, or just to another amp. This allows you to use your receiver as a preamp only. The phono input allows for the use of a cartridge with a moving coil, a moving magnet or a ceramic, The black plug is a shorting plug which helps keep noise to a minimum from the phono preamp. You have a very nice old Pioneer. A little Deoxit and a good cleaning is probably in order but it is built like a tank and probably has some life in it yet.
__________________
Sansui G6000,7070
Pioneer SX1250,SX1280
Kenwood KR-8010
Onkyo TX8500II
Pioneer CTF950,Akai GX-S80
DCM TF-600,TF-400 CX-17+ KL Quartets
  #3
Old 08-06-2007, 07:07 PM
AK Member
Thanks for your input ... KB ... is my assumption about switching it on Inter-coupled for normal use correct? ...
While cleaning it ... I discovered an opening (1.5" x 3") on one of the sides with 2 tube-like (they have pins) pieces inside(see pic ... I removed the smaller one (which says ... Cds Lamp unit ... on the beige top) to get a better look at it) ... what are they? ...
  #4
Old 08-06-2007, 07:34 PM
jwrags's Avatar
jwrags jwrags is offline
AK Subscriber
Chip:
I have one of these with the remote and manual. From the manual:
For remote control of FM or AM "Auto" tuning and volume adjustment, connect the REMOTE CONTROL UNIT to the REMOTE socket on the front panel, and connect the CdS UNIT to the 7P socket on the right side.
The manual goes on to say turn the volume down on the SX-2500 and use the remote volume to control the volume.
I don't currently use mine, but it is a keeper.
Best
John
__________________
  #5
Old 08-06-2007, 08:31 PM
buckleboy's Avatar
buckleboy buckleboy is offline
AK Member
Speaker jack adapters
I have one of the SX-990 units. Very well built and packed with features. Pioneer made some substantial gear back then.
You can get the Pioneer speaker jack adapters for those here for $8.50:
http://www.vintage-electronics.cc/vparts.html
__________________
"Everyone always talks about the weather, but no one ever does anything about it!"
Audiokarma
  #6
Old 08-06-2007, 10:14 PM
AK Member
Thanks, John ... what is the Cds Unit? ... I didn't check it but I am guessing the 7p socket is the smaller piece (on the left in my pic) ... so what is the function of the other larger piece (on the left in my pic)? ...
  #7
Old 08-06-2007, 10:17 PM
AK Member
Quote:
Originally Posted by buckleboy View Post
... You can get the Pioneer speaker jack adapters for those here for $8.50:
Thanks ... fortunately, I have accumulated a few extras ...
  #8
Old 08-07-2007, 05:51 AM
jwrags's Avatar
AK Subscriber
Chip:
The smaller socket on the left is indeed where you plug in the CdS UNIT. If you don't plug it in, the remote will not work.
The larger socket to the right of this is where you plug in a transformer for a Moving Coil cartridge. Pioneer Model PP-402 MC Transformer, separatry available
Capitalization and misspellings are from the manual.
Best
John
__________________
  #9
Old 08-07-2007, 08:05 AM
AK Member
The larger socket to the right of this is where you plug in a transformer for a Moving Coil cartridge. Pioneer Model PP-402 MC Transformer, separatry available ...
Thanks ... are there model #s on the tuning remote that plugs into the front and/or the Cds Unit that plugs into the side? ...
  #10
Old 08-07-2007, 09:59 AM
jwrags's Avatar
AK Subscriber
No model #s that I can find either on the units or in the manual. I think in Dr Strangelove's scans there is a picture of the remote on top of the receiver.
Best
John
__________________
Audiokarma
  #11
Old 08-07-2007, 10:49 AM
AK Member
Thanks ... I saw that pic ... was hoping to track down an orphan tuning remote using a model # ...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
The Tube Store
Grant Fidelity
AudioClassics
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
TR Audio
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
Politicalchat.org
Yesterday's Audio
Zebra Cables
Radio X
MCM Electronics
Videokarma.org
Avanti Audio
esmokers.org
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©Copyright 2002-2009 AudioKarma.org, All rights reserved.
