ncwitte
Hi, I have a problem and I am not sure where to post it. Hopefully this isn't too wrong a place.
We just built a new house and I installed some JBL speakers in the ceiling and a JBL HTI88 subwoofer in the wall. I puchased an Advent 300 receiver to power the ceiling speakers. To power the sub, I bought a new AudioSource AMP100. Upon receiving the amp, I discovered that in order to use it in mono mode I had to have a mono input. To get this signal, I took a pair of RCA cables from the 300's preamp outputs, connected each channel to a Y cord, routed one side of the Y back to the amp inputs on the 300, and then ran the other half to another Y connector, which I then plugged into the amp. The power amp was set to mono. I think the amp is rated for a minimum of 8 ohms when so set.
The HTI88 has two speakers in it and two crossovers. It has provision for hooking up each speaker separately to an amp, but since I only ran one wire to that location, that's not an option. It also has shorting straps to connect the two speakers so that they can both be run from one input.
So last night, I was listening to some lame disco crap from the seventies and I turned it up and smoke-tested the power amp. Literally. There was a crack and a bunch of smoke came out of the amp; now that I let all the smoke out I can't get it back in and the house stinks. Ideally, I'd rather not repeat this performance. So I am trying to figure out what caused the problem. Was it
a) the woofer was operating at less than 8 ohms because I was using the grounding straps;
b) my combining two line level inputs was a big no-no;
c) my amp was simply defective; or
d) I got what I deserved for listening to lame disco crap?
FWIW, here is the manual for the speaker:
http://manuals.harman.com/JBL/HOM/Owner's Manual/HTI88 OM(web)4-19-05.pdf
I checked, and it doesn't appear to say that when the grounding straps are used, impedance goes to 4 ohms.
I looked at the manual for the amp, and it appears to be rated only for 8 ohm loads when bridged.
Assuming that (a) (or (a) and (d)) was the correct answer, any suggestions for an inexpensive amp to replace this smoke-tested unit? We ain't listening to classical here!
Thanks.
Norm Witte
Thanks.
Norm Witte
