Susurus
Resolution:6.62×10^-34
Dahlquist vs. Vandersteens - I'm baffled!
or, not baffled?
Who's the King of Imaging?
Full range, please?
Today's score: Dahlquist DQ-12's
Wonderful sonically, like nothing I've heard... (initial test in progress... details coming...)
Cosmetically -- expected wear... 5/10. Touchy pull-around parts of the shear, light grill fabric --less acoustically interfering-- :thmbsp:
Very odd metal mesh-like back grill protecting the top mid/tweeter. Lends a decidedly unpolished, no-nonsense look. The support bracket is remniscent of a mini Jubilie... Contrast that with the Heavy lower deck... at least .75" thick everywhere (42 pounds overall.)
On the support for the front grill frame and the back metal mesh there's more angularity than a Stealth Bomber... hmmm it's black... I'm calling this my Stealth Dahlquist.
Dusty...which means these are not new things with recycled model numbers... :thmbsp:
Spikes. Hmm. carefull!
First time I've ever heard baffle-lessness, but after reading everything on the Vandersteens, I knew I must have an example...
These are 3-way, upright, not the 5-way DQ-10s that are more talked about...
To compare,
Dahlquist DQ-12 msrp $1500 19?? 3-way, phase-aligned, complex "time-delay-corrected" crossover design.
"The 1" Tweeter and 5" Midrange are Vifas.
8" Woofer is a Gefco 4 ohm (?)
in a sealed 0.64 cubic foot enclosure.
Crossovers are at 400 Hz and 3500 Hz.
38-22,000 Hz with a +/-2.5 dB from 52-20,000 Hz. "
Phased Array
Impedance: 8 ohms
42" High x 16" W x 9" Deep
43 Lbs. Net
The back says 40-125 watts; there are 2 fuses, 3 amp and either a .8 or an 8 amp! :sigh:
Only 1 of the fuses was good, one fried and 2 missing! I replaced them all... but that upper .8 or 8 has me concerned...
Maybe somebody blew the fuses and stored them for 20 years!
These appear efficient; didn't expect that (even next to my Klipsch R-F7s which are 102 dB/W) but nowhere could I find any dB/W specs... only that DQ-10s were madly hungry...
Considering how few net references on the DQ-12 I found, maybe they were only made for a brief interval. Maybe just before the company went south in 1993?
or, not baffled?
Full range, please?
To compare,
Phased Array
Impedance: 8 ohms
43 Lbs. Net
= Lose :sigh:
Grey color matched, not a recent refurb---too much dust everywhere!?
