speedracer
Well-Known Member
Hi, Wondering if anybody has any info on this TT, bought it mant MANY years ago, thinking of bringing back into service. Thanks.
Well, What should I / could I do to this TT ? and why is sooo "sensitive" ?Don't throw to much money after it, the P- series wasn't really that good. As you say it is sensitive and with only a bit more than 6kg it is understandble why. Don't get this wrong, yamaha never made really bad stuff, P- series just wassn't in the better end of things.
About the P-550 1980-82
I belive that arm is a very simplyfied version of the one on the PX-2 and 3 (not to compair the P-550 with those).
Drive is as you say FG Servo DD.
Motor: 8 Poles coreless Hall Motor.
The platter is 30cm, 1,6kg.
S/N 77dB.
Wow and flutter: 0,015% WRMS
The arm:
Stright tube arm
Effecktive lengh 222mm
Overhang 16mm
Recomended carthridge weight: 2,5g - 10g
Headshell: Resin 20% carbon fiber, ADC type 2,8g
arm + cable 100pF
Dimensions: 440x132x372mm, 6,8kg
Not sure what you mean by sensitive, the P-450 that I use in my shop does not strike me as overly sensitive. If you bump the chassis it will skip but so do most TTs.
Record size selection for automatic operation.
17cm = 7" (45s)
30cm = 12" (LPs)
You have to dampen the vibrations, I don't remember how the P-550 is build but it might be the feet that make the suspension like on the PX-2 and 3. If it is troubled you can hear the famous walking across the room (if doing so) and then you need to fix the suspension in the feet (on the TT ). One thing many TT fans also do is to add weight to the body and also sound dampening material, but do a search on this, there are many people here that know much more about this than I.
I only know that the P- and TT- line was the low of what Yamaha ever did in TT's, but remember as I said earlier; Yamaha never brought out really crappy units, they where always in the top of class if not best.
Unless the platter and tonearm are suspended seperately from the plinth you will hear that through the speakers, heck even my Planar 2 is THAT sensitive.
plinth ?? so this is normal, for ALL TT's ??
So it sounds like I need a better TT !The plinth is the base. It is normal for all TTs that don't have a platter and arm suspended independently from the base. In those tts when you press on the platter it bounces up and down. In non-suspended tts like yours the isolation is usually done via springy or spongy feet. And yes, when you touch any part of the tt during play you will hear it through the speakers. So the answer is not to touch it.
If you do it's not for that reason. There are plenty of excellent unsuspended turntables. As merrylander said, his Rega is just as sensitive.So it sounds like I need a better TT !
