Wonder if McIntosh intends to "trickle down" the sentry monitoring which is a feature of the MC2301's?:scratch2:
SENTRY MONITOR TUBE PROTECTION
The output tubes have limits for the maximum amount of power they can handle. The MC2301 output stage and power supply have been designed to allow high current flow into properly matched load impedances. If, however, a short circuit or very low value of load impedance is applied to the output of the MC2301, destructive current levels could be reached. The Sentry Monitor circuit prevents this. The circuit senses the dynamic operating time, voltage, and current of the amplifier output tubes and confines it to nondestructive levels. Sentry Monitor does not limit the power output available from the amplifier. Sentry Monitor also protects the entire amplifier circuitry in the event that a failed Output Tube causes higher than normal current to flow. To prevent destruction, the MC2301 power is turned off. The protection mode is indicated by the flashing of the red standby indicator on the front panel. The Protect Mode is reset to normal operation by cycling the MC2301 power off and then back on with the POWER switch.
I know first hand this sentry monitor works -- or at least I believe it kicked in - as had one tube (GL Reissue) that would cause the left amp to go into shutdown (I decided to test all 15 remaining tubes on my tube tester -- they were fine). The one which caused the amp to shutdown failed several tests on my tube tester.
By the way, I recommend having spares -- I have 12 KT88's in reserve.
