Morden2004
Relaxin'
This thread is locked and can only be updated by a moderator. If you have a contribution for this thread, send a private message to @dlucy the current moderator.
The Exclusively Sansui FAQ List
- FAQ 1
Can I make a new cabinet for my Sansui?
Here's a good one for cabinet making.
http://audiokarma.org/forums/showthread.php?t=54070 - FAQ 2
What are fusible resistors?
No Sansui FAQ list could be without mention of fusible resistors
http://audiokarma.org/forums/showthread.php?t=47170 - FAQ 3
How do I fix an intermittent 'Separated/Connect' switch?
All about the problematic connected/seperated switch on the big G.
http://audiokarma.org/forums/showthread.php?t=50077 - FAQ 4
I need bulbs? (Part 1)
Bulbs and lamps. This only one. Maybe someone could recommend more.
http://audiokarma.org/forums/showthread.php?t=51405
See: FAQ 13 below for more bulb information. - FAQ 5
My Sansui is blowing fuses when powered up. What shoud I do?
http://audiokarma.org/forums/showthread.php?t=55659 - FAQ 6
My Sansui is staying in protection mode. Why?
Protection fault
http://audiokarma.org/forums/showthread.php?t=26786 - FAQ 7
How do I fix the dial lamp on my 9090/9090DB?
9090 Dial Lamp
http://audiokarma.org/forums/showthread.php?t=51901 - FAQ 8
What is DC-Offset and why should I care?
EW's DC offset and bias thread (#1 in everyone's book) ...
http://audiokarma.org/forums/showthread.php?t=5634&highlight=offset - FAQ 9
Are replacement transistors safe?
Identifying counterfeit output transistors and using OnSemi MJ21193/MJ21194 instead of the originals.
http://Audiokarma.org/forums/showthread.php?t=53323&highlight=mj21194[/QUOTE] - FAQ 10
I have scratchy controls and a noisy volume control. What to do?
Cleaning switches and potentiometers {The Morden2004 method}
Cleaning Controls - FAQ #11: Re-wiring the lights on a 8080/9090
Lights out in an 8080/9090? Here is a repair tip that will remove the light circuit from the selector switch which often fails.
"With the top cover removed, looking down on the right side, there is a pc board about 4" x 5 " that the selector switch is mounted on. On that board there are connection plugs. Second from the right there is a connector with a orange, grey, black and red wire attached. There is an open location on that connector. Move the red wire(~6.5 vac) from the end position to the vacant position next to the black wire. This new position will tap into the 6.5 vac supply that the source selector uses. Now the tuning lights will be on all the time and the orange source lights will switch on and off as the function selector changes(am,fm,phono,aux,dolby fm)
- FAQ 12
How do I sell my surplus gear here on AudioKarma?
Subscribe, then use the Bartertown forum. - FAQ 13
Where can I get replacement lamps for my classic Sansui? (Part 2)
AudioKarma member Dave Wojo (dgwojo) has a great site for ordering bulbs. Click this link: dgwojo
AudioKarma member Denis (dhenryp) also sells lamps for classic Sansui gear. Check out eBay member ID 'dhenryp' on eBay
or contact either member using AudioKarma email. - FAQ 14
I have heard about the problems with glue on component boards. How do I get rid of it?
Click the link below.
Sansui glue - FAQ 15: How do I tell what year my Sansui equipment was manufactured?
Easy! The serial numbers on most Sansui equipment follows a standard;
FF Y MM ####
where FF = a Factory Assembly Line number
Y = last digit of the year of manufacture (you need to know the first year a unit was built - see the Sansui Database reports)
MM = the month of build where 01 = January and 12 = December
The remaining 3 or 4 digits are sequentially applied on the line in sequence.
Example:
AU-999 Serial Number is: 222010985
Manufacturing line #: 22
Year: 1972 (first year for the AU-999 was 1969)
Month: January
Serial component: 0985
- FAQ 16: What does the Connected/Separated switch on my Sansui xxxx do?
Read this excellent explanation by our very own EchoWars here .
- FAQ 17: What is a 'Poor Mans Variac' and how do I build one?
Read this thread for an explanation of the PMV here
- FAQ 18: crosspoint screws in Sansui are not usually Phillips - they are JIS
- More FAQs or useful threads on Sansui gear:
- FAQ #19: Access to speaker relay & meter lamps on 9090/9090DB
In the thread link below, Dr*Audio explains how to access the speaker relay, and tips on replacing the meter lamps with LED's.
It has a couple of small problems (I'll get to that later!); but much to my chagrin it has two of the dreaded F-1040-1 boards.
