I have a pair of Advent AS2's and would like to make a change to the network that would yield more power to the tweeter.. I have a backyard knowledge of crossovers networks.. For those who can help but don't know this speaker Advent the off brand *now* Name of the newer Advent SA2's I will describe them and then network. They are a floor standing 2 way system with two 6 1/2 woofers and one soft dome liquid cooed tweeter.
The crossover network works well and is well thought out, sound is nice and smooth.. My goal is just to let a bit more power to the soft dome and not change it's crossover point..
Ok back to the network.. It has dual binding posts and component wise it has two chocks one larger wire wound and one smaller ion core wire wound, it also has two caps one large and one smaller with two resisters wire wound in a ceramic oblong square.. One looks to measure 5.4 ohms and the other 1.2 ohms.. I'm not sure that this matters as I think I have to short out one with a pice of wire to boost the power to the tweeter.. The speakers are rated at 200 Watts continuous power and think it's rated so high do to the resisters in the network on the most part.. They would more then likely never see more then 100 clean watts.. Can someone help me out with the info I have provided? Thanks! George
