bricktop
Couch woofer
Hey all,
I decided to do a little instructional thread here for the newbies to help people get the most out of their posted photos. I put in the DIY forum because, often, people take pictures of inside their electronics equipment to show problems, parts, wiring, etc. With an image that is is designed to fit the limits of AK picture posts (for JPEG, it is 900x900 and 190KB max.), everyone will be able to easily see what is trying to be pointed out . This way, it will be easier for people to give the best advice for whatever the problem, or just see your fancy equipment better .
1) Download free and install "The GIMP" Image editor from http://www.gimp.org/.
2) Transfer your image from you digital camera to wherever you see fit.
3) Run "The GIMP" and open the image file via: FILE -> OPEN
4) Cropping the image will let you focus in a part of the picture you are really interested. Therefore, less pixels and memory are wasted on unimportant parts of the picture. To crop the image, click the rectangular select tool in the top left of the GIMP. A yellow tooltip will highlight the button if you hold your mouse over it for a second, to make sure you have the right tool. After the rectangular selection tool is selected, click and drag a rectangle over the portion of the photo you are interested in. If your entire picture is of interest, skip to step 6.
5) Click IMAGE -> CROP TO SELECTION to discard the rest of the image
6) If your image is larger than 900x900 pixels, scale the image to the AK maximum of 900x900 pixels (or whatever size you desire) by clicking IMAGE -> SCALE IMAGE. Under "Image Size," make sure the units are set to pixels and click in the box of width or height which has the largest dimensions. Type in 900 (or your size choice) and click SCALE. As you click SCALE, notice the other axis (either width or height) will change so the picture's aspect ratio stays the same. The number will also change if click in the other box (either width or height). Here, my photo, after cropping was 1050 width by 825 height. I typed in 900 for the width and the height automatically changed to 707 pixels.
7) To view the full size image, select 100% from the zoom dropdown box.
8) Now to save the image, click FILE -> SAVE and click on the "Advanced Options" arrow. Unclick all but the "optimize" checkbox. The "EXIF data" is information about the camera that took the photo, an can take up quite a bit of space. On my camera, the EXIF data is commonly around 50KB, which will take up a quarter of the space allowed for AK pictures. It is unnecessary for our purposes, and it can't be removed with Microsoft Image Picture Editor or Paint (that I know of). The 'thumbnail' is a small version of the file attached to make previews quicker, also unnecessary here. Click "Show preview in image window" to get a real-time preview of what the saved image will look like. In the "Quality" adjustment bar at the top, adjust the quality until the image file size is as high as possible but below 190KB. My file here is 184KB. Click SAVE, that's it! Ready to be posted. :thmbsp:
sticky perhaps??
sticky perhaps??
