Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Infinity Loudspeakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 02-22-2008, 06:37 PM
pioneervato's Avatar
pioneervato pioneervato is offline
Monochromatic Fanatic
Location: The Arizona Desert Between Phoenix and Tucson
Infinity Reference 1 Bookshelf Speakers
OK. I picked these up today at GW for $12. They need refoams. Since I can't play them until I re-foam them:
1. I was wondering how these little bookshelfs hold up to others of similar size, etc.
2. Any advantage to the graphite composite of the speaker cones vs. paper?
3. Any crossover upgrades that would be worthwhile doing (other than just re-capping)?
These are my first set of home audio Infinity speakers which I might use at work once I replace the foams.
Thanks.
__________________
  #2
Old 02-22-2008, 10:04 PM
VintInfinity's Avatar
VintInfinity VintInfinity is offline
Tactophonic
1. For $12 they are awesome, and can probably beat many new models costing much more. I've never heard this model, but I have a pair of Entra One that sound pretty good. The Reference One are older models, and are most likely of higher quality.
2. The graphite looks really cool, and is very rigid compared to paper.
3. No idea... I'm sure something exists, but it is probably not needed. New caps probably aren't either, although it couldn't hurt.
  #3
Old 02-22-2008, 11:00 PM
Tedrick's Avatar
Tedrick Tedrick is offline
Infinity-phile
Infinity Reference One
Frequency Response 55Hz - 25kHz (+/-3dB)
Crossover Frequency(ies) 4000Hz
Sensitivity 90dB (1 watt/1 meter)
Nominal Impedance 6 ohms
Power Rating 10 - 75 watts
Woofer 6" (15.2cm) IMG
Tweeter 0.75" (1.9cm) Polycell
1) For $12, you did well. Although they don't use the EMIT tweeters from the higher-end Infinity's, these should still sound pretty good.
2) Injection-molded graphite woofers have a light, stiff cone that will be far less prone to break-up than a paper cone. The bass should be fast, clean and tight.
3) These are new enough that you really shouldn't need to do anything to the cross-over. However, a quick check on the Infinity Systems website shows that factory crossovers are still available for this model for the incredible price of $16.70 each.
__________________
MAIN SYSTEM
VPI Aries I - Lyra Clavis - Sutherland PH3D
Music Hall Maverick - Adcom GFP-750 - Forte Model 6 - Infinity Modulus/Genesis G928
OFFICE
VPI Classic - Lyra Delos - Dynavector P-75
Burson Soloist - HiFiMan HE400
Nakamichi TR-3A - KEF Ref 102
  #4
Old 02-23-2008, 04:13 PM
V'ger V'ger is offline
AK Member
If you need the crossover schematic, PM me and I will tell you how to find it on harmon.com. It is not a public link so I am unwilling to provide a direct link, but you can discover it yourself.
  #5
Old 02-23-2008, 04:32 PM
nukeme's Avatar
nukeme nukeme is offline
AK Member
I'm a big fan of this series. I've had a pair of the reference one's, I'm listening to a pair of reference two's right now and I have a pair of reference six's in my main system. The reference ones are very nice little speakers with nice bass for a small package. The interesting thing about those woofers is that they're two pieces. If they are just separated (which is common) you can glue them back together for a temporary fix and see how they sound(that way if you don't like them you haven't invested time or money in foam). I did this with my reference one's and they worked great. If the foam is starting to break down then you'll need to refoam them.
Audiokarma
  #6
Old 02-23-2008, 04:46 PM
Tactophonic
Quote:
Thanks for elaborating... that's what I was trying to say, but got lazy...
  #7
Old 02-23-2008, 04:52 PM
onepixel's Avatar
onepixel onepixel is offline
I've been trying to decide which small speakers to take to the Sacramento get together. The similar bookshelf sized Infinity RS-9s with the composite cones/polycells are on top of my list. Beating out the B&W DM602, Thiel CS1.2 and ADS L8es. I never got around to refinishing them so they look kinda shabby so the 2nd place ADSs will most likely be making the trip. The RS-9s sound excellent and nearly as good as my RSbs with emits.
I think you will be very pleased with the Reference 1s.
  #8
Old 02-23-2008, 09:54 PM
Rich_Guy Rich_Guy is offline
AK Member
I have a pair of Infinity Reference 1 speakers I would like to sell, if anyone is interested send me a PM. I have them in storage in the original box, they were like new when I put them there. I only used them as rear surround speakers and they were taken very well care of. I am going to get them out of storage take some pics and put them on ebay. I have not seen them in a couple years but they have been stored very well and I expect that they are still like new.
  #9
Old 02-24-2008, 02:48 PM
AK Member
Quote:
There are three Infinity speakers that are very similar: RS225, Sterling SS2002 and Reference One. The crossover design is almost the same design (one is 8 ohms), they use the same woofer, and they only really vary on tweeter design and cabinet volume. The Reference One has the smallest volume cabinet, so I would expect that it has the weakest bass. The SS2002 and RS225 have about the same volume but the RS225 has a better finish and slightly larger tweeters. All three sound great, though.
  #10
Old 09-04-2011, 07:43 PM
laidler laidler is offline
AK Member
Just today I bought at Hope Chest, at 10 dollars for the pair, a couple of these speakers in pristine condition. I haven't hooked them up yet and given them a listen, but I do have high hopes for them. I'll post some pictures soon if you like.
OK, hooked them up, they sound really good. Not the biggest bottom end of course, but man, so far the best sounding speakers I've had. Nice.
Audiokarma
  #11
Old 11-19-2012, 01:35 AM
so_ein_pech's Avatar
so_ein_pech so_ein_pech is offline
toob noob
Just got a pair of these at the thrifty store. $7 a piece (like someone is going to buy just one...) Almost minty except for the disintegrated foams. A $5 refoam job later (used generic 6.5" foams from bootapest2) and they are singing away.
Have been A/B'ing them with a pair of Boston A40's for the past few days its a close call, but I have to say, so far I like the Infinitys better. Bostons are a little mellower and "fat" sounding, but Infinitys sound more accurate and realistic, to my ears, with better imaging. I imagine, as the surrounds loosen up, they will only sound better and better.
Pretty proud of myself for the bang-up job I did on the refoams. It looks alot better than the slop job I did on the Bostons. Practice makes perfect, I guess.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Audio by Van Alstine
Capacitor World
AudioFriends
Meistertech Solutions
Vintage Home Audio
Okki Nokki
Analog Engineering Associates
Wargos Electronics
Organ Donor Parts
Hudson Valley Hi Fi
Sound Stage Direct
Take Five Audio
Parts Connexion
Howard Products
Simply Speakers
Audience AV
Amplifiedparts
AudioClassics
The Tube Store
Audio Doctor
RSL Speakers
Many Moons Audio
DeWick Repairs
BOI Audio Works
Yesterday's Audio
MCM Electronics
Videokarma.org
Politicalchat.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
