Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > General Audio Discussion
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 02-23-2008, 03:04 PM
acdc7369 acdc7369 is offline
AK Member
Most powerful receiver ever manufactured?
The Pioneer SX-1980 was rated at 270 wpc...however, in the September 1978 issue of Audio Magazine, Leonard Feldman did a spec test on the SX-1980 and concluded that the rating of 270 watts per channel was too conservative. He stated in his report, "Though the new [IHF mandated] 'Dynamic Headroom' measurement is specified in dB, it should be mentioned that based upon the short-term signal used to measure the 2.3 dB headroom of this amplifier, it was producing nearly 460 watts of short-term power under these test conditions!"
At 460 watts per channel (2.3 dB dynamic headroom) into 8 ohm loads with THD 0.03%...even beating the Technics SA-1000... doesn't this technically makes the Pioneer SX-1980 the most powerful receiver ever manufactured? What do you guys think?
  #2
Old 02-23-2008, 03:53 PM
Jon S Jon S is offline
AK Member
I think the Marantz 2600 receiver was the highest rated receiver at 300wpc. marnzt also was very conservative in rating their units so it is possible that this unit could even exceed your Pioneer.
__________________
Is that great sound or what?
  #3
Old 02-23-2008, 03:54 PM
Inkara1 Inkara1 is offline
AK Member
We'd need to see the same test done on the Technics to know for sure.
  #4
Old 02-23-2008, 04:01 PM
Glen B's Avatar
Glen B Glen B is offline
AK Member
Sansui G33000, also 300 w.p.c. ?
  #5
mhardy6647's Avatar
mhardy6647 mhardy6647 is online now
AK Member
In terms of FTC-compliant power specification, it was the Technics SA-1000 at 330 wpc.
__________________
Set the Tone Controls for the Heart of the Sun... -- KeninDC, Anno Domini MMXI
Audiokarma
  #6
Old 02-23-2008, 05:42 PM
Soran's Avatar
Soran Soran is offline
Accuphase
why bother anyway ? it's the sound quality that matters, 10 watts of perfect music on a pioneer or sansui sounds more powerfull than 1000 watts on a disco amp.
be serious ! 270wpc i saw the mighty quadral titans of 260lbs/piece almost killing at 2x300 watt on the pioneer meters. wich speakers can handle this amount of power perfectly pure without any more distortion than usual ?
__________________
Accuphase E-405, Infinity IRS Gamma
  #7
Old 02-23-2008, 07:06 PM
ManFromPorlock's Avatar
ManFromPorlock ManFromPorlock is offline
AK Member
Power levels like that are probably better delivered by separates, anyway. Easier to lift, if nothing else.
__________________
Being cheap isn't a character defect -- it's an art form.
  #8
Old 02-23-2008, 08:35 PM
KlipschFan61's Avatar
KlipschFan61 KlipschFan61 is offline
Smooth Jazzer
That Technics would sure look good next to my SL1210..
__________________
Denon AVR-2106 DCM-390 Yamaha CR-1020 :music:
'78 Klipsch LaScala KSC-1 KSB 1.1 KG 1 JBL PSW-1000Ohm Walsh2 Sansui SP-1500
Technics SL-1210MK2/SL-DD33 Sumiko Pro-ject 1
AT440ML Signet TK7E Grado Prestige Silver/Gold -Ortofon Super OM10
Sennheiser HD-600 Grado SR-80
  #9
Old 02-23-2008, 09:48 PM
toxcrusadr's Avatar
toxcrusadr toxcrusadr is offline
Hideously Deformed
Quote:
Ohh, m'groin...
__________________
Spend your resources and talents doing good.
  #10
Old 02-23-2008, 09:55 PM
Gibsonian's Avatar
Gibsonian Gibsonian is offline
AK Member
The Marantz 2600 and the Technics SA-1000 would need to be tested with the same conditions to compare. I'm thinking the Pioneer would come in last place here.
__________________
Champion Of Higher Fidelity
Audiokarma
  #11
Old 02-23-2008, 10:11 PM
whoaru99's Avatar
whoaru99 whoaru99 is offline
AK Member
Quote:
Originally Posted by Soran View Post
...10 watts of perfect music on a pioneer or sansui sounds more powerfull than 1000 watts on a disco amp....
Surely you jest?
__________________
And then one day you find ten years have got behind you.
No one told you when to run, you missed the starting gun.
-Pink Floyd Time
  #12
Old 02-24-2008, 12:14 PM
AK Member
The SX-1980 was designed for Pioneer's HPM series of speakers, wasn't it?
  #13
Old 02-27-2008, 05:18 PM
John L's Avatar
John L John L is offline
Chief Bloviator
I have a question: why is it so important to be able to have a sound system that can work within the entire SuperDome? Who gives a contential Damn about the most powerful amplifier.
I guess you may be able to tell that I am a big valve person, so anything over 35-40 watts RMS is overkill anyway.
  #14
Old 02-27-2008, 05:41 PM
AnalogDigit's Avatar
AnalogDigit AnalogDigit is offline
It's all good!
Has anyone who had these receivers had it up to their max power? I wonder if listening at those levels for a extended period of time would effect your hearing.
For myself, I have an SX-950 that I only crank it up to 1/4th of the way up. I don't like it too loud anyways. I once had it to 12:00 position and I could not hear myself talk or yell.
__________________
Realistic, Sony, Denon, Pioneer, Aiwa, Onkyo, Akai, JVC, KEF, Magnavox, Hitachi, Superscope, Sherwood, Yamaha, Project One, Panasonic and a lot of other stuff.
  #15
Old 02-27-2008, 06:20 PM
Njord Noatun Njord Noatun is offline
Banned
Based on nominal power output, the answer is simple: Technics SA-1000.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Tone Arm Audio
Tuner Heaven
Classic Sound Repair
Take Five Audio
Cabledyne
Audience AV
BOI Audio Works
BD Enterprise
Amplifiedparts
Howard Products
RSL Speakers
Audio Art Cable
Salk Sound
Siliconray
Musical Paradise
Vinyl Magic Record Cleaner
Urban Antigue Radio
Audio Salon
Many Moons Audio
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
The Tube Store
Simply Speakers
AudioClassics
DeWick Repairs
Audio Doctor
Parts Connexion
MCM Electronics
Vintage Electronics Repair
Herbies Audio Lab
Politicalchat.org
Sound Stage Direct
Antique Radio Classifieds
FM DX Antenna
Videokarma.org
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
©Copyright 2002-2012 AudioKarma.org, All rights reserved.
