Audiokarma.org
Audiokarma Featured Sponsor
Audiokarma will be offline March 7th and 8th
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-04-2008, 02:32 PM
daer21 daer21 is offline
AK Member
JVC A-K350 in protect mode
I have a JVC A-K350 that I got that I am 99% certain is in protect mode. However, I can't for the life of me find out how to get it out. Does anyone know?
Thanks,
Matt
  #2
Old 03-07-2008, 12:32 AM
AK Member
Help?
  #3
Old 03-07-2008, 12:46 AM
avionic's Avatar
avionic avionic is offline
Aim High !!!
Location: Fort Dodge, Iowa -Northern end of"tornado alley"
Its in protect mode for a reason.Either DC voltage present at the speaker outputs,abnormal power supply voltages detected,failure in the protect circuit.If your familiar with trouble shooting "hot chassis",reading schematic diagrams,using basic testing equipment.Then first verify proper power supply function-Next verify there is no DC volts going to the speaker outputs,this may require making the measurement before the relay.If you detect DC ,start checking for shorted output devices ie. Transistors,Mosfets,hybrid chip amps,etc. If no DC is detected look for a problem with the "protect circuit" possible bad capacitors,transistors and/or chips.
If your not familiar with trobleshooting electronics......Take it to a Pro..
__________________
Bridged Yamaha B-6's l C-85 l PF-800/DL-160 l CA AZUR 740 l
NS-1000M's
Keep it pithy!
RET USAF 1978-1998
"In Artie we trust"-- PPP
  #4
Old 03-07-2008, 10:49 AM
AK Member
I'm larning *humor*. but in all seriousness there is no DC voltage at the speaker outputs. I did, however, find to burned out resistors in the section directly after the preamp. Also the main power relay in the amp section will not actuate. IF I force the relay to actuate then I get static, indicating that the amplifier circuits still are somewhat there. I'm working on gettomg tje tramsostpr testing working. I'm beginning to suspect an issue in the low level inputs. If I hook up a dub deck to it and set the unit to dub and I get a signal this should indicate that the preamp section is still functional. First I need to replace those resistors however.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Okki Nokki
Capacitor World
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
The Tube Store
FM DX Antenna
Musical Paradise
Many Moons Audio
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Audio Doctor
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
