Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-12-2008, 07:32 PM
Cut-Throat's Avatar
Cut-Throat Cut-Throat is offline
AK Member
Mitsubishi Receiver DA-R20 - Worth Fixing
A friend of mine brought over a Mitsubishi Receiver DA-R20. It plays fine for about 5 minutes after a cold start, but then starts 'sputtering' in both channels for a couple minutes before it finally goes silent. Does this on all selections FM, AM, AUX etc.
Is this worth fixing or even looking at. The thing weighs about 50 pounds.
  #2
Old 03-12-2008, 08:10 PM
Brian's Avatar
Brian Brian is offline
An Old Geezer
Won't know until you get an estimate. Could be something simple. If it has preamp outputs / main inputs, and you have another unit with the same. Test the preamp and then the power amp to see which has the problem. It may help to identify which. If the power amp, you may want to use it as a tuner/preamp and if the preamp, then you can use the tuner and power amp.
  #3
Old 03-12-2008, 08:16 PM
Cut-Throat's Avatar
AK Member
Quote:
He wants me to fix it! - Ha! - But you have a good idea on the Pre-amp Power amp thing. I am guessing it could be a transistor. I could first figure out where the problem is and then start spraying components with some cooling and see when it turns back on.
  #4
Old 03-12-2008, 09:23 PM
daddydlb's Avatar
daddydlb daddydlb is offline
AK Member
Thats a hard one. I have the DA R15. IMO no where in the league of say a 2220 Marantz or an SX 550 Pioneer. Who knows, a little fiddling might pay off.
__________________
Sansui 9090DB
Thorens TD 145 MkII
Yamaha DVD C750
Teac A4010SL
Klipsch Forte II's
Polk Monitor 10 II's
  #5
Old 03-13-2008, 12:47 PM
KingBubba's Avatar
KingBubba KingBubba is offline
"Too Much Stuff"
Your real problem may be finding a service manual. I have the DA-R7 and I can find nothing on it.
__________________
Sansui G6000,7070
Pioneer SX1250,SX1280
Kenwood KR-8010
Onkyo TX8500II
Pioneer CTF950,Akai GX-S80
DCM TF-600,TF-400 CX-17+ KL Quartets
Audiokarma
  #6
Old 03-13-2008, 02:16 PM
Cut-Throat's Avatar
AK Member
Quote:
No, He brought me the service manual as well!
  #7
Old 03-13-2008, 03:19 PM
MitsuMan MitsuMan is offline
AK Member
Quote:
  #8
Old 01-07-2009, 07:54 PM
xoaphexox's Avatar
xoaphexox xoaphexox is offline
Supernatural Anesthetist
I have one on my bench right now and it's giving me issues.. I think the proprietary power output pack may be bad in the right channel. It has the -1.2V supply for a while and then jumps to -12V after a while and sounds distorted as heck. Left channel plays fine so I replaced every electrolytic cap on the power and driver board and no luck. I then swapped all the left channel trannies for the right channel ones and the problem stays in the right channel - must be that output pack....
The problem exists whether I use a separate preamp or not so it must be in the power amp methinks.
Driving me nuts.
  #9
Old 01-07-2009, 09:00 PM
ryuuoh's Avatar
ryuuoh ryuuoh is online now
FFXIV Summoner
Solder joints?
__________________
Akai AS-970 AA-5000S
Technics SU-8080, SL-1300, SL-20, SA-5
Luxman L-80V, L-430, T-240
Yamaha NS-670, NS-690II, NS690III, T-80, T-70, M-50, C-50, CD-S700
Denon TU-800, TU-1500RD
Bozak MB80
Sansui TU-717, 9090
sun tan, drink in hand
  #10
Old 01-07-2009, 09:02 PM
xoaphexox's Avatar
I pulled the STK-1060 and determined that it is malfunctioning. I need to find a replacement STK-1060 or compatible.
Now the real fun begins
Audiokarma
  #11
Old 12-08-2009, 02:56 AM
Allen9959's Avatar
Allen9959 Allen9959 is offline
AK Member
I just bought a DA-R20 about 2 hours ago. Have it hooked up. I like it. The phono section isn't bad and the hybrid digi / analog tuner is cool. It's a little bland sounding, but overall not too shabby. reminds me of a poor mans Sansui integrated. I think it's worth getting fixed depenindg on price... it would make a good back up amp in any event. Plus, look at all the functions you're getting, both preamp in and out, MM/MC phono and rack handles.
  #12
Old 12-08-2009, 06:26 AM
Gang-Twanger's Avatar
Gang-Twanger Gang-Twanger is online now
AK Member
What do you think of the sound during the first 5 minutes? And what does your friend think of the sound (regardless of his desire to get it fixed). I'm asking because he may end up being even happier with a mid '70's Sansui (or one of the other sleeper manufacturers who made good stuff back then). Phono preamps were made so-much-better in the '70's than they were ten years later (and the same goes for everything else under the hood). Also, it may be a cheaper option as well, especially if he doesn't need much wattage. But if he's into a more-"accurate" '80's sound then maybe he's got the right unit. Actually, the '80's units are even cheaper than the '70's stuff in a lot of cases (Not my kind of thing though).
I avoid just about anything
__________________
MAIN: 1964 Fisher 800c / 1963 Wharfedale W90's w/ oil caps / 2012 Wharfedale 80th Anniv. Dentons / Grado RSII's
W90's & 800C DEMO: https://m.youtube.com/#/watch?v=izlGluuOb44
"Your rhymes are jokes like Dangerfield's.... Boy, I'll tell ya'...." - Craig Mack
  #13
Old 12-08-2009, 06:33 AM
Cut-Throat's Avatar
AK Member
Considering that I started this thread almost 2 years ago, I can vaguely remember it. The unit is long gone from my place. As far as a cheaper option, he already owned this from way back and to him it was free.
  #14
Old 12-08-2009, 06:52 AM
AK Member
Ohhhhhhhhh. Oops.
Thanks a lot, Allen9959. I answered this thread because he had, and it was at the top of the "most-recent" list (or whatever they call it). Ahh, forget it. I'm not even an NAD fan to begin with. I bought mine as the result of someone else's suggestion (which turned out to be a wrong one because I realized that it wasn't the type of sound I was looking for).
So what did you finally end up doing with it? And what's that semi-Jubilee-looking speaker in your avatar?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
