Friday Night throw together
Windwalker
Was having a hard time doing something to something that needs to be done-if I want to enjoy them
So thought about it a little bit while watching some Madness(Go DUKE)
Went to Lowes and picked up the following
Any guesses as to what it might be?
either the starts of a tater gun, or a port plug.... and one hell of a big port at that..
however, I'm wondering if that razor blade had something to do with this wild idea..
Respectable guesses
Razor is not part of it
Renslipevol- i need to hang with you, if you know how to fill that bowl. That's be more more like the AK part hookah,hmmm might be a good idea for the get together though
Next pic hints
and
Thanks for playing, all
The unveiling of the completed project
Hence forth known as WindWalker's Cheap Friday Night's Record Cleaning Apparatus or Simply-
The WW-RCA(TM)
another view
Ready for use
adjustable mounting options
hhhm.. that's a pretty cool idea.. I either need to build me something with vacuum.. or go buy something.. I'm getting tired of listening to dirty albums..
Windwalker,
You inspired me to put more thought into my proto-type and address the issue of wet labels. I took your ideas and modified them to fit my 2 X 4 base that works well with my sink and faucet. The following pics are self explanatory of the basic construction.
The key is the 4 inch diameter can lid. It comes from a 28 ounce tomato can. Remove the lid by cutting it off with the can opener sidewise so that the cutting blade goes through the can body versus the top. This retains the seam (the folded metal) which you want for added rigidity.
Since I build gas powered model airplanes, I had large diameter silicon fuel tubing to use as an O-ring. I used a trick I learned to overlap the ends and make a cut with an exacto knife so the butt joint has the proper angle. The use of the clamp is only so I can take the photo. I willing wife would work just a good. A bead of silicon adhesive glues the O-ring in place.
To build the O-ring I tried a couple of different methods of joining the ends. A flexible piece of rubber with the same ID of the silicon tubing would be my first choice. Since I don’t have any of that lying around used a piece of insulated 12 ga wire bent with the radius of the can lid.
The other stuff and notes:
¼ inch threaded brass rod.
9/32 inch brass tubing.
¼ in brass nuts.
¼ brass washers
The brass tubing slides over the brass rod until you cut it with a tubing cutter. The tubing cutter deforms the end so you will have to fix that. The steel spacers were used only because I had a small piece of brass tubing already cut which was too long. You don’t need them you are willing to make careful cuts on the brass tubing.
The whole assembly pulls out of the 2 X 4 so you can wash the flip side, which is why the threaded rod is so long.
All this material is available at a hobby store, OHS hardware and your local grocery market.
Zoot Allures
I put a Lightnin' Hopkins album on my gig and the label doesn't fit under the lid.
My test album has a 3.5 inch label. I checked a few other titles and 4 inches seem to be the norm.
I thought I had a winner.:no:
It's better than trying to hold it in your hand and clean.
Isn't DYIing fun?
Honey, I'm going to Lowes be back in 20 minutes
1.5 hours later, countless drawers opened, pieces fit together and an idea brewing, you finally show back up.
I think Webster's defines that as putzing
The gasketing part was\is a bit of a sticky point for me as well. I've tried a piece of CAT5 cable with a couple pairs pulled out. Worked ok but believe there is better. Maybe Autozone has a 4" "O" ring-that's what I keep hoping to find.
Your Can lid gives me an idea though, my plastic container lid is not quite rigid enough maybe I could combine the two, hmmmmmmmm
Well gotta work on taxes. Mo Later.............
Great thread you guys, thank you for helping crystallize and complete my partly formed thoughts. I was trying to think of how to build such a thing as that a month or two ago.
I'm Thinking maybe a different direction on this, now as I take a break from all that is W-2, W-92, 1098s
Instead of reinventing the wheel and trying to make something thats firm enough, how's about something pre-made
Made a stop at Harbor Frieght and saw a couple things and their prices are certainly right
1st item
Sanding pad
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94763
This one has a firm black rubber\plastic backing pad that is covered in some softer red rubber. The red rubber piece is covered in velcro-rip that off
It's slightly larger than 4.5" at the velcro end ~4.75"-not sure if that's too wide or not
2nd item
I can't find it, on-line. Believe it was a 7" rubber grinder packing pad, was like 3 bucks. This would have to be cut down to the correct size but believe it should be easy enough with a razor knife
3rd item
Just say this one while looking for #2. May have to check out tomorrow
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96306
Now all of these are going to require some step down something or anothers to convert their larger hole to something that can be locked down or at least has a smaller spindle adapter. Wonder if maybe a forstner\t-nut epoxied in might do the trick.
Food for thought or we could just break down and buy one off that site or get a real RCM-nahhhhhhhh
Cool idea. I never had a label really get bothered by getting wet, but sometimes the inks come off a bit on the wife's nice embroidered white tea towels. :-o
Auto parts stores sell gasket material by the sheet - red rubbery stuff. One could cut any size gasket yuze wanted. Would that help?
Another idea
I solved my problem of the metal can lid being too small to cover 4 inch diameter labels.
I cut 4.5 inch diameter disks from two trashed thrift store albums and made new O-rings from silicon tubing and glued them down. Cutting the disks is a lot easier than you might think. I made a crude circle gig and used a soldering gun with a knife tip to cut a rough circle. Using the same circle gig, I used a surform file to finish it.
I refined the wood 2 X 4 a bit by putting a piece of the 9/32 inch brass tubing in the hole that holds the spindle. You can pull out the assembly and flip the album a lot easier than just a bare hole.
The adhesive I used contains toluene. It dissolves vinyl so you only have one chance to glue the O-ring down right. I highly recommend it. Ace hardware stores sell it.
http://www.sashcosealants.com/Home_Improvement/Lexel.aspx
Here's what she looks like without an album on it.
Both disks are the same size. The red label is a 4 inch label, the blue label is 3.75 inch.
I won't bore anyone with details, if someone wants clarification on what I've done, ask here or send me an email.
As discussed in post 14
I went with the harbor freight sanding pad
Stopped by Lowes and picked up a package of (3)1/4-20 flanged hex nuts
Here are the results with notes.
One on left is as it comes in package, with velcro attached. On the right shows velcro removed. Slip a razor knife down the side to get it started and peel the rest back. That new surface is rubber(closed cell foam).The 2nd one I did is not quite as rough, knew how to do it.
You have to drill\punch the center hole in the red rubber
Flange nuts shown
top view
Place flange nut in top of sanding disk-these fit PERFECT. Before the next step, I used an awl with nut in place to get center line for shaft or rod to go through. The nut acts as a very handy guide. Once center hole was punched I drilled a 5/16" hole through the red rubber
I then used some two part epoxy and fastened the nut to the sanding disk flange
Completed, on LP-goes right to the edge of lead-out. :thmbsp:
Using Saterfi's threaded rod idea-I used 1/4" because the flange nuts fit the pad flange better, you now have a self tightening cover that keeps your labels dry
Enjoy
I like the industrial strength of your design. It’s a forklift compared to my bicycle.
How does the new assembly fit on a counter/sink to rinse and wash the albums? A few photos would be nice.
Haven't quite decided on that part yet. Contemplating borrowing the pressure washer idea. Looked at Lowes last night for the tips but at 25 bucks(pack of four-various angles) I won't be doing that. Will look at Harbor Freight later today.
I can always go back to my original holder-The cutting board, I found a wooden one at GW, so can do like you did and drill some various holes
