Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 03-09-2004, 04:02 AM
Jupiter1610's Avatar
Jupiter1610 Jupiter1610 is offline
AK Member
Philips 312...decent intro turntable?
I will be purchasing a Philips 312 turntable w/ AT cartaridge on Thursday, and this will serve as my first introduction to the world of vinyls. It will run $125, and I was wondering if this seems to be a fair rate? Was this a pretty decent turntable in its day? Did it stack up against Thorens models of the same era? Would it be worth putting a decent cartaridge on latter? The turntable will be used will the following-
Sansui TA-500
PSB Alpha A/V (hopefully Epos ESL3s soon!)
Thanks.
  #2
Old 03-09-2004, 02:58 PM
Don C's Avatar
Don C Don C is offline
AK Member
The Phillips is a pretty nice table. I worked on one a while back, and the guts look the same as a Bang & Olufsen. Very simple construction, they use the least material that they can possibly get by with. Just about the opposite of a Dual or a Garrard, I think that those two use as many parts as they possibly can. I wouldn't rate the Phillips quite as high as a Thorens though.
  #3
Old 03-09-2004, 03:05 PM
Andyman's Avatar
Andyman Andyman is offline
Scroungus Stereophilus
Location: 15 miles North of Canada, East of Grumpy. West of Kegger
I used one for a while, but finally decided to keep the Thorens TD-160 I also had. I liked mine and the auto lift at the end of the lp is a nice feature.
The $125 price seems steep to me though; what all do you get for that? Shipping included? Cartridge? I ask only because it seems to me you could get a Thorens for not much more money, so why not?
PS. I just went back and checked out Ebay and the highest a 312 went for recently was $50.02, which makes that $125 look like a real premium price.
__________________
"Do or do not. There is no try"
- Yoda
  #4
Old 03-09-2004, 03:13 PM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
AK Member
The Philips GA212 and later 312 were the default entry-level "good" tt's when I started in this hobby (at least in Baltimore). It's a good basic belt-drive tt with suspended platter and tonearm and a lightweight arm well suited to the high-compliance cartridges that were popular in those days. The 212 was (IMO) better built than the 312. They are semi-auto tt's, with optical auto shutoff at the end of the record (IIRC the 312 also lifted the arm at shutoff, but not the 212). Plus, of course, they offer the cool touch controls (as does my somewhat later, but not as nice overall, Philips AF877)
I agree they're not in the same league as their Thorens contemporaries, but decent and nice looking tt's in their own right. They go for a little too much $ on eBAY for my tastes.
__________________
Preamps need drive, not gain. - G. Kaufman
  #5
Old 03-09-2004, 04:10 PM
bear-hifi's Avatar
bear-hifi bear-hifi is offline
AK Member
I don’t know anything about the Epos but don’t under estimate the PSBs… Place damping sheets on the inter walls of the cabinet and replace the x-over parts with better ones then replace all the wiring with heaver gauge OFC wire. It will sound a LOT better as it already has good drivers. PSB only problem is that there cabinets are not the best and the internal parts (wiring, caps) are on the low end. The drives (Vifa I believe) or very good and the design is good as well.
Just my 2 cents and it may not be worth that..
Audiokarma
  #6
Old 03-13-2004, 02:51 PM
AK Member
The turntable included a Audio Technica cartaridge. The piece is in very good condition w/ no scuffs or scratches on the dust cover. I bought the table locally so shipping was simply the cost of gas. I replaced the cartaridge w/ a Grado model that my father gave me, and it sounds absolutely splendid. Do any of you think that the Philips is enough of a table to later put, lets say, a Sumiko Blue Point on?
  #7
Old 03-13-2004, 03:40 PM
Don C's Avatar
AK Member
I don't know anything about that cartridge. I do know that the arm on the Phillips is low in mass, and will work best with a high compliance cartridge. Maybe a Shure or one of the higher compliance Ortofons would be my suggestion.
  #8
Old 03-14-2004, 11:15 AM
Brian's Avatar
Brian Brian is offline
An Old Geezer
The table was an alternative to the AR during that period and better regarded than most of the Japanese tables in the same price range in terms for pulling the music. The tonearm for the original price of the table was inexpensive and excellent whereas the AR arm out of the box needed a real laboe of love. The suspension on the AR was better and the Philips platter rings. That all said side by side on a firm isolated surface the Philips was the better. Not designed to go up against the sterophile tables such as Thorens, Transcriptors, etc. There was a more expensive 427 but these are rare.
  #9
Old 09-02-2010, 01:52 AM
Arkay's Avatar
Arkay Arkay is offline
AK Member
Quote:
Sansui TA-500
Thanks.
The Philips 312 is a quite decent basic TT, a good choice for someone getting into vinyl-spinning, as it will be fairly easy to service and will sound pretty good.
Not to nit-pick, but please don't refer to vinyl records as "vinyls". You just come across as a clueless newbie when you say that, as it is a mistake made mostly by kids too young to have been around when records/LPs were mainstream, so they don't know the correct usage. Vinyl is the material that the records are made from, not the individual disc(s). You may refer to "vinyl" as a generic (uncountable) term, as in, "I'm into vinyl," or "vinyl spinning." You may use it as an adjective, as in "vinyl records" or "vinyl pressings". But when referring to the individual black vinyl disks with grooves pressed into them, please say "records", "LPs" or even "discs" --or if you wish to use a slang nickname, "licorice pizza(s)" (once the name of a record store chain) --but never "vinyls". You go to the store an buy a record; you may even buy "some vinyl", but you do NOT buy "a vinyl" or "some vinyls"!
(I didn't write that to criticize, but just to help. Please take it that way. )
__________________
People take different roads seeking fulfillment and happiness. Just because they're not on your road doesn't mean they've gotten lost.
-- Dalai Lama
  #10
Old 09-02-2010, 02:13 AM
danj's Avatar
danj danj is offline
modern primitive
$125 for a nice 312 with a good cartridge is a fair and honest retail price. It might have been overpriced a few years ago but good quality vintage turntables are becoming less common and prices are going up.
At least that's the way it is in my area.........
Enjoy your new-to-you turntable!
__________________
http://johnson4096.wix.com/modern-primitive
Audiokarma
  #11
Old 09-02-2010, 02:23 AM
catman catman is offline
G'day all, I heard somewhere that turntable teams well with the Shure M97xE cartridge.
Yes Arkay ok on the term 'vinyls'. Yes I agree. Perhaps I'm showing my age but that term just seems plain wrong to me! 'Records' will do fine with me! Regards, Felix aka catman.
  #12
Old 09-02-2010, 09:27 AM
KentTeffeteller's Avatar
KentTeffeteller KentTeffeteller is offline
Gimpus Stereophilus!
The common nickname for the GA 212 and GA 312 was "Poor Man's Thorens". The AR also was as well. The AR overall was a better turntable but the tonearm was better on the Philips. Both when set up right were fine performers. The TD 150 and 160 back then were the best of the middle class turntables. The Transcriptors back then was higher end but had a finicky reputation. The Linn LP-12 was considered the better in high end then or the Sota.
  #13
Old 09-02-2010, 10:01 AM
Isotonic's Avatar
Isotonic Isotonic is offline
A Delicious Avocado
Though they can be found for less. $130 is a fair price for a working 312 in great condition. I have a 212 that I found for $30, but it was a piece of work. I spent hours removing belt goo and even after a good clean up it was far from pristine.
I have a Shure V-15 II on mine with a Jico HE stylus on it. It sounds very very good. My Grado Sonata probably sounded better on it, but I ultimately felt I was wasting my Grado. Which sounds much better on a better, much more expensive TT/Arm.
That said, my Phillips is still an excellent TT. I use it all the time and never feel dissatisfied. I can say for reference that I like it more than my Dual 1218 and Pioneer PL-518, two other solid tables that are well regarded.
  #14
Old 12-01-2011, 09:38 PM
Luke57 Luke57 is offline
AK Member
Need a cartridge and stylus for my Phillips 312 TT.
Anyone care to offer up a few recommendations?
Thank you.
Also, what it is the difference between at GA-212 and GA-312? I sit only that the tone arm lifts at end of record?
Thank you
  #15
Old 12-02-2011, 12:05 AM
allan1832 allan1832 is offline
AK Member
I don't know if this will help, but I have a Grado Red on my GA-212 and it seems to work well. It sounds great anyway. The person who had the table for most of its life had an older Grado on it and he seemed to know what he was doing, so I just stuck with Grado. I've never seen a 312 so I'm not real clear on the differences.
Allan
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
©Copyright 2002-2014 AudioKarma.org, All rights reserved.
