Okay, I tested the Monoprice budget Video Component Cables and compared them to the Petras. I'm including this here for the benefit of this discussion, but will also post it in a separate thread. Here are the product links:
http://www.monoprice.com/products/p...d=10235&cs_id=1023501&p_id=320&seq=1&format=2
http://www.sjgreatdeals.com/pet10-5010.html
Equipment: Pioneer PL-630 equipped with RCA jacks, Shure M91ED, Yamaha C-65 preamp, Sennheiser HD-595 headphones.
The Monoprice I ordered was the six foot set of 5 which included the two audio cables. The video cables were well constructed of a flexible rubber/plastic with moulded on gold-plated RCA connectors. The audio cables were very flexible, very thin cables, but with the same connectors. There are no metal covers and there is no way to remove and reuse these connectors on other cables. When plugged in they held snugly--just right IMO. Both video and audio seemed to be adequately shielded. There was no hum with either.
Just a review of the Petras for those unfamiliar. The plastic cable sheathing is rather stiff--the major complaint with these. The connectors are moulded on, but there is a metal cap which can be unscrewed and removed, enabling them to be swapped for identification, or removed altogether for jacks that are too close together. The connectors are gold-plated and fit snugly but after time can become loose and may require a mild crimp. Adequate shielding with no hum.
Capacitance measurements:
Petra = 18pF/ft
Monoprice Video = 25pF/ft
Monoprice Audio = 67pF/ft
Test results: The MV sounded very good with good high end and bass, good clarity and soundstage. The Petras maybe a smidge better. The MA better than I expected to be honest, but a bit attenuated (reduced) at the high end.
I would continue to recommend the Petras, which are cheap to begin with, but for even greater savings, the Monoprice Video Component Cables are fine. I'd stick with the group of three and forget the audio cables, unless you want to use them for line level ICs in which case they're fine.
http://www.monoprice.com/products/p...d=10235&cs_id=1023502&p_id=960&seq=1&format=2
http://www.monoprice.com/products/p...d=10235&cs_id=1023502&p_id=961&seq=1&format=2
Keep in mind nothing designated "audio" today is geared toward phono applications. We AKers live in a different world than the rest of society. So discard manufacturer labels and look for the characteristics that count for phono apps: Low capacitance and adequate shielding. While clearly not all video component cable is as low in capacitance as the Petras, it is still generally lower than cable with other designations. And for DIY I continue to maintain that shielded, coaxial cable is the most appropriate construction for phono apps.
