Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 04-03-2008, 11:02 PM
Mr. Lin's Avatar
Mr. Lin Mr. Lin is offline
AK Subscriber
Is the Sansui SR-333 a good turntable? (need advice here)
I have the option of taking one of two Sansui turntables for free from my girlfriend's father. Off hand I can't remember the model number of the first one, but it's suspended, wood base, belt driven, S-shaped tonearm. When I asked about it here a while back someone told me it's ok but at the lower end of Sansui turntables.
The other one I currently have sitting on my floor. It's a SR-333, direct drive, very heavy. I plugged it in and it works, and in a minute I'm going to test it out on headphones. The only thing that concerns me is that the entire tonearm assembly seems to move back and forth to a very minimal, almost unnoticeable, degree. So perhaps there are bearing issues?
Anyway I'd like to know if this table is considered a potential performer or not. It would be nice to own a direct drive table for once, but I like the appearance of the other Sansui better.
__________________
  #2
Old 04-03-2008, 11:08 PM
Mr. Lin's Avatar
AK Subscriber
Aha, I just found my older thread. The other turntable is a Sansui SR-212. So between the two of these, which would be considered the better turntable? I definitely prefer the appearance and design of the SR-212.
__________________
  #3
Old 04-03-2008, 11:39 PM
Mr. Lin's Avatar
AK Subscriber
Just because I enjoy talking to myself I'm going to add one more thing...
I just hooked it up to my headphone amp, set the VTF and gave it a quick listen with a beat up Bowie record. It sounded pretty awful, very muffled. Part of the problem is that one of the RCA pins is actually bent so it doesn't fit properly into the RCA jacks on the phono preamp. The other issue is probably the cartridge, which is an Empire 6000, and it sure doesn't look like much. That doesn't matter because I have plenty of good backup cartridges.
__________________
  #4
Old 04-04-2008, 09:34 AM
Sansui Louie's Avatar
Sansui Louie Sansui Louie is offline
Curmudgeon
The 212 is a belt drive, the 333 direct, me thinks. Personally, I'd also take the 212 as the build quality is probably a bit better than the later 333.
  #5
Old 04-04-2008, 10:22 AM
BrocLuno's Avatar
BrocLuno BrocLuno is offline
AK Member
Mr Lin - take them both. Put one in a box in the basement or garage. Let's start with the one you like. The belt drive probably needs basic maintenance. If it spins, that's all you can expect from a donor. Lets do all the basics and see where you end up before passing any sound judgment?
Let's get some De-Oxit, WD-40, some sewing machine oil in a clock oiler and see where we end up? Did you download the owners and service manuals for these from Vinylengine.com? Does the spindle have sealed bearings or open ones? Have you spritzed the speed controls, headshell contacts and all switches? Have you tried slightly rotating the headshell leads to get fresh contacts (with a bit of De-Oxit)? What's the stylus look like on the Empire? Tried Magic Eraser and cleaned the stylus? Tried to pull the stylus and reinserting to make sure it's seated correctly? How's the alignment (you KNOW how important that is)?
If it takes interchangeable headshells, get a few or borrow one from the other machine, mount your Silver and spin it with that to get a better idea of the condition of the tone arm wiring and such. Get yourself down to Wally World and get some "Video" patch cables and drop by Radio Shack and get some bulkhead RCA connectors and fix away. THEN run another sound test?
Turntableneedles.com in Corvallis OR will get you another cheap after market stylus for the Empire (or an OEM if you want?) and a new drive belt, probably with free USPS shipping. Once that's taken care of, you can sound test AGAIN. Then we'd like to hear your impressions of these tables My suspicion is that they will surprise you with their sonic performance. You'll likely be within 10% of your higher end tables when all serviced and finally running with a good cartridge
__________________
Broc Luno
Some Orphaned Silver
Mitsubishi, MCS, Scott, Nikko ...
A/D/S, BA, EPI, Infinity ...
Audiokarma
  #6
Old 04-04-2008, 05:48 PM
Thom's Avatar
Thom Thom is offline
AK Member
I have a SR-333 I got from my brother and am very pleased with it. No tonearm issues. Rock steady speed. I use it for recording.
__________________
Vinyl is a disease which attacks that area of the brain desiring digital recordings. Once you catch it, you are cured.
  #7
Old 04-04-2008, 07:15 PM
Mr. Lin's Avatar
AK Subscriber
Yikes! I've never had to bring a vintage turntable back to life, and I guess I didn't realize all the things that need to be done. I do have some De-Oxit and WD-40, so that's a start.
I'll point out here that I can't have both the turntables, it's one or the other. Frankly I don't know why this is since her father doesn't listen to vinyl at all anymore, but I'm not going to question it because it's very nice of him to give away either of these. I've pretty much decided I want the SR-212, and Broc when you see a picture of it you'll probably understand why, it's a very nice looking turntable and the build quality does seem better to me. If I did keep the 333 I would not be interested in using that Empire cartridge, I'd keep it for a possible trade-in, then use my Silver, M97XE, or 10X5 even.
So I'm going to return the 333 and bring the 212 home, then I'll go from there. I suspect the 212 is in better condition overall because I know he took care of it, and the 333 was something he just won off ebay, and it doesn't look to me like the previous owner particularly cared about it. I'll start by getting a new belt, then we'll move on to all the bearing stuff like you suggested. Then I need to try and figure out the approximate mass of the tonearm, which someone in my other thread suggested was around 15 grams. There's very little information available on this tt.
I kind of wish it had a low-mass tonearm so I could play around with some AT or other high-compliance cartridges, but I'm sure I can work something out with what I have. Thanks everybody, and if anyone else has anything to add please do so.
__________________
  #8
Old 04-04-2008, 09:48 PM
BrocLuno's Avatar
AK Member
It's a Japanese mass market TT. It'll play an AT just fine. They were almost all engineered to work with each other. It may not have had an AT when originally shipped, but believe me they all know their specs and no one engineered a system that excluded the other major suppliers - even Denon who made their own cartridges (among others).
It might be 15 grams, but seems to be a little too heavy for me? It's also not likely that Sansui made their own arms? It's most likely that they bought them in from another supplier? I'd just treat it like a 1200, with the exception of the geometry and distances. I'm sure it will play any good Japanese cartridge just fine
__________________
Broc Luno
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
