thefragger
Certified Crazy.
Today was a beautiful, sunny, and sorta-kinda warm day-- the kind of day that made me want to tear down a TT and clean every last tar-coated part of it.
I'll post more photos as I take them, but I've got a lot of homework to catch up on now :nono:
Short list of problems;
-The balancing mechanism doesn't work at all, if anything, setting it up to the max puts the arm in equilibrium, with the stylus hovering over the record. I used a penny for a bit then switch to two bus tokens (aluminum, much much lighter) to keep the stylus on the record.
-The original cart is in pretty bad condition (no output), so I took the headset from my Toshiba for testing. I found that the arm doesn't swing to the centre of the record and this causes tracking problems past half-way... can this be fixed by aligning the cart at an angle inside the head shell?
Since the original cart is toast, does anyone have any suggestions about what I should replace it with (under $50 for a cart and stylus, I want to use the Denon shell)? Maybe upgrade the tonearm as well (at a MUCH later date)? I'll come up with more questions as I think of them. Does anyone have any info on this TT for me?
Thanks!
Philip.
Thanks!
Philip.
