The Shure M97xE is NOT nude. If you doubt this, check the documentation at vinylengine.com. When Shure made nude ellipticals, the designation ended with a "D" as in "M91ED."I would chose the SHURE myself over the ORTO. The SHURE has a NUDE 0.2 x 0.7 Elliptical Stylus + the Dynamic Stabolizer. The Orto is a BONDED 0.3 x 0.7 Elliptical and lower compliant.
BUT...it depends on what you listen to as well...
Joey
Joey
Whenever a question about the M97XE comes up I usually insert my opinion that it's "sound" is boring. Just based on what people have said here on AK about the 2M series I would recommend that in a heartbeat over the Shure.
Shure M97XE vs ORTOFON RED??
Bigerik: New design? The 2Ms??? Uhm... Actually, I'd hardly call further refining the old LM/OM/OM Super generator, putting it into a new, fancy looking case (body) and swapping the FG70 for a Shibata stylus on the top model a new, clean sheet of paper design. To me, that's just another variation - and not even an unproblematic one, due to the ample dimensions of the body as well as the more critical reaction of the generator on cable & input capacity...
Greetings from Munich!
Manfred / lini
P.S.: To be fair though, I'd think it's hardly possibly anymore for any maker to come up with anything really new in the realm of phono carts based on electromagnetic induction - as more or less any interesting type of generator design, magnet, cantilever and coil material as well as stylus shape have already been tried for several decades...
You must grant me a little hyperbole when making my case....![]()
Anyhow, there is certainly some interesting new technology in the 2M series, admittedly more in the black and bronze. New, high tech material for the bodies (Noryl, a plastic/glass combination). Upgraded silver coated wires. Improvements, if not radical changes to the motor assembly, leading to a noticeably different sound and much higher output.
Well, granted - but then you also have to grant me playing the devil's advocate, especially when I think your case is rather weak...
Well, first of all, Noryl isn't generally a combination of glass and plastic. There are plenty of different Noryl types, some available with glass reinforcement. If you want more info, GEPlastics.com offers quite a bit... Also, Noryl isn't any new for Ortofon - e.g. you'll also find it on their more recent MCs Samba, Salsa and Tango as well as the older MC1/MC 3 Turbo, X5 MC and X1 MCP...
And if you look into that generator design, it really is just yet another version of their old VMS design. And the tuning trend is quite easily visible, too: LM series had 600 Ohm, 500 mH and recommended load capacity of 400 pF, OM series as well as 305/310/320(U) had 750 Ohm, 450 mH and 200 to 600 pF and OM Super series as well as 5x0MkII had 1000 Ohm, 580 mH and 200 to 400 pF. And now we have 2M with 1300/1200 Ohm, 700/630 mH and 150 to 300 pF. Well, and whether it's the silver plating on the OFC wire that makes a difference or maybe just less windings - who knows?
So, in my understanding, that all in all rather boils down to further development of an old design than to a radically new one.
Manfred / lini
My thoughs exactly. And while I have not tried any of Ortofon's newest seiries yet, I have been favorably impressed with the upper-end of the prior OM Series, like the OM-30 Super. That is one MM cartridge that reminds me more of an MC sonically, and represents a good value in an inexpensive cartridge IMHO.I disagree with this completely. Maybe the fact that I have never heard a Shure that I love has something to do with it....
Anyhow, the Ortofon is a NEW, clean sheet of paper design. Yes, Ortofon is actually using modern technology to produce new and better designs. To me, it seems that Shure has pretty well given up on phono cartridges. The tooling for the M97 is long since paid for, so they can keep turning them out on the cheap. If Shure was truly interested, they would have thrown some engineering resources into the V15-V to keep it in production.
It actuallly begs the question of whether or not there are phono catridge engineers left at Shure.
Keep in mind that there is a LOT more to the sound of a phono cartridge then the size and shape of the stylus....
E
