i finally got all my parts from mouser, and am home sick today (seriously :sigh:, bad sore throat, flu-symptoms, etc.), so i figured on starting the re-resistoring and recapping of my pilot sa-232.
i am doing one tube socket at a time, rather than trying to do one component at a time. on v7, i am replacing a 120ohm 2W carbon film resistor with a metal film resistor; the leads on the replacement are shorter (overall length is shorter). can i use wire of the same AWG, bent and soldered, to extend the leads? or will i get resistance penalty?
also, a question about heat shrink. i've some 1/4", turns out to be waay too big (doh!). what size do people use to isolate leads (like the long leads from a capacitor, etc.)? do you put that on before soldering? it seems one does, but how does one keep it from melting at the soldering end?
thanks...
bill
thanks...
bill
