Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 04-24-2008, 07:50 AM
Chazb11's Avatar
Chazb11 Chazb11 is offline
Vintage Human
Question What causes hum in vintage receiver??
I have an old Electro-Voice receiver that will hum after being on for a short while. It's not very loud as you can only notice it when the music stops.
Turning the receiver off for just a few seconds will make the hum go away but it comes back in a minute or two.
What would be a likely cause?
__________________
I reject your reality and substitute my own.
  #2
Old 04-24-2008, 09:14 AM
Mattwizz3's Avatar
Mattwizz3 Mattwizz3 is offline
Web-er-web user...
The power filter caps are probably starting to age and are not up to spec. When the caps get older they aren't able to 'smooth' out the power as effectively so you get ripple in the power thats feeding your amp, that is probably what you are hearing. Luckily they are relatively cheap and easy to replace.
__________________
Never gonna buy new again!*
*(Now that Ive blown my budget)
  #3
Old 04-24-2008, 10:59 AM
wizargoz's Avatar
wizargoz wizargoz is offline
AK lives in AZ!
Answer: Vintage receiver forgot the words to the music?
  #4
Old 04-24-2008, 11:28 AM
tcdriver's Avatar
tcdriver tcdriver is offline
AK Member
Quote:
I agree with the above. Failing electrolytic capacitors are the most likely cause of hum in vintage receivers. Another cause of hum is ground loops causes by poor design. Not that common, however, I have run across this a few times.
__________________
Round and Round it goes
  #5
Old 04-24-2008, 05:25 PM
Chazb11's Avatar
Vintage Human
This is what I suspected. I hope I can find a cap that will fit inside this receiver! It's a 22000uF cap and it fits into metal spring clips so the new cap will have to be nearly the same size physically. There is no room to relocate the cap.
__________________
Audiokarma
  #6
Old 04-24-2008, 05:31 PM
bobschneider's Avatar
bobschneider bobschneider is offline
AK Member
Quote:
Modern caps tend to be physically smaller than older ones, sometimes very much so. For a power supply cap, if the modern 22000uF ones you find in the original voltage are too small to fit, go to a higher voltage - that won't cause any operating problems, and won't affect the sound. You might also go to a higher uF value - some people find that improves the sound (tighter bass), but it can put more strain on the transformer, and/or cause fuses to blow from start up surges. Personally, I'd be willing to try a bigger cap, but no bigger than 150% of the original uF value.
__________________
Mac MCD201, MR78, C41, MC352, MPI4
ML Ascents + Descent, Linn LP-12, Revox B77, Squeezebox Touch
Citation 1 & 2, Marantz SA-11S2, Technics SP-15, Onkyo T-9090II, PMC OB1i, Otari MX5050 B-3, Squeezebox Touch
  #7
Old 04-24-2008, 05:53 PM
kretinus's Avatar
kretinus kretinus is offline
squanto was a fool
Use self adhesive foam weatherstripping to increase the effective diameter of caps that are physically smaller than the originals, just wrap it around the cap where the clamp encompasses it.
Something I picked up from a Yamaha tech
__________________
Welcome to the B12 version -2.0...
  #8
Old 04-25-2008, 07:14 AM
myrgatroyd myrgatroyd is offline
AK Member
Hmm. My english is not such as good...
Does "hum" definitly means "electrical low frequenced sound" or just "low frequenced sound"?
That means: Can you hear the hum in the speakers or is it the receiver itself?
Once had a Tannhauser with a terribly transformer, gave it away, my wife could not stand the sounds the trans made. Problem was caused by vibrating iron plates.
Then: Is the hum present only at one source (TT, TD) or present at all? Then you could have a problem with your connection.
Otherwise I would change the caps like the folks here do advise.
You should do it, because you will have that problem in nearer future anyway, even if your caps are actually in good condition.
Last tip: Turn the power plug 180 degree. (Not in the oven. Left to right.)
Yours
Alex
  #9
Old 04-25-2008, 07:55 AM
Chazb11's Avatar
Vintage Human
Quote:
Yours
Alex
Now that's funny right there!
Also going to add a little more info here...the hum gets more noticeable the longer the unit is on. No hum at all when first turned on and everything is cool. In short it seems to be related to operating temp, the cooler it is the less hum. Does this still sound like just a cap failing? (the unit is not overheating at all, just warming up normally)
I'm going to replace the cap anyway. There is only one and it's 2000uf, not 22000 as I said in the first post. (i don't type so well). I think I have found a suitable replacement at Mouser > 2100uF 150v and the size is right. (CGS212U150RC3 is the mfg. number, if you're interested)
__________________
  #10
Old 04-26-2008, 06:41 AM
AK Member
Is the hum in the speakers or does it come from the unit itself?
That transformer in my Tannhauser acted similar. The sound got worse when the radio played some minutes, got then to a certain level.
It was the iron plates vibrating due magnetical fields in the coil.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Analog Engineering Associates
Okki Nokki
Hudson Valley Hi Fi
Capacitor World
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
The Tube Store
FM DX Antenna
Musical Paradise
Many Moons Audio
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Audio Doctor
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
