MoreCowbell
I'm almost done refurbishing an Akai GX-77 but have a question before I button it up.
I discovered that the small tab on the automatic loading roller had broken off and the spring that attached to it was nowhere to be found. I repaired the roller mechanism and have attached photos of it as well.
Yesterday a small dusty spring fell out from the deck as I tipped it over. I have the service manual and went back over it and can't find a spot that this might go to except the automatic loader. In the process of this project the unit has been completely disassembled during which I took many photos, so I have a fairly good reference in addition to the service manual.
I am trying to determine if this is indeed the auto loader spring but am a little puzzled because it is a VERY strong little spring. One of the attached photos shows the found spring along side my repair. As you can see it looks to be right size but I can't imagine that the small plastic tab which broke off would have near the strength to have EVER held it.
For those that currently own a GX-77, could you tell me if this looks like the spring on your decks?
To check this on an operating unit, you would have to power it up without a tape and then turn off the power after selecting the appropriate function button (either FF or Rewind) to get the auto loader to the top. You could then peak behind the black cloth slot. I've attached a photo of that for reference.
Thank you very much,
Paul
Paul
