This thread is not about permanent storage of LPs; it is about how to store the LPs you keep out on regular rotation.
In the record store, they use cardboard boxes, approx. 13" wide: The jacket is facing the customer, and with a flick of a finger, he can leaf through records at high speed and with very little jacket wear.
Contrast that with a home setup where you keep the records, spine out, on a shelf. To access an album, you need to:
The latter method is not only slow and inefficient, it also creates all kinds of wear issues on sleeve corners, faces and seams.
Does anyone know of LP storage devices that provide the face-out benefits of the "record store box", but at the same time has enough WAF to be presentable, say in a living room setting?
- Put your index finger on the top corner and tilt the album out, putting pressure on the lower corner.
- Grab the album and slide it out on the lower seam and against the faces of the adjacent albums.
- If it is not the album you want, slide it back in again.
- Repeat as needed.
