I have been asked to post details of my open baffle project.
Well my journey started very cheap. I took some nice 8" drivers salvaged by someone else from a philco solid state console and some free scraps of particle board and made my ghetto OB system as a proof of concept.
I was absolutely blown away by the results so I stuck a dome tweeter on top and supplemented with an 8" AR sub and used it as my main system for quite some time. There is a small top plate and unequal side plates on the baffle.
As you can see the Spousal Acceptance Factor is quite low on those so I began work on a more polite system.
I had some old Radio Shack 5 1/4" FR drivers which appear to be Foster OEMs so I decided to use those as the basis of the project.
The silver ring is just an adaptor used to mount the driver in a car. These were of course removed before use. These drivers start rolling off at about 200Hz (most likely due to a stiff surround) but that was OK as I planned to use a helper woofer anyway.
Being a cheapskate I chose to use a budget 10" woofer from Parts Express. The rather high Q is appropriate to a small baffle system such as this one.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-325
My design was intended to mitigate one of the downsides to an OB system. For an OB to perform to the utmost it needs about 3' of breathing room behind the speakers. So to get around this I made them into something that someone would want to have out in the room a bit. They are little knick-knack tables on which one can place flower arrangements, pictures or whatever.
So step one is to make baffles using some junk wood from an organ console that I parted out. It sounded pretty good so I began building the rest of the table. using pine 1x6 boards that I picked up at Lowes.
I use a cheapo version of bi-amping currently that takes advantage of the FR driver's natural rolloff. I daisy chain the main receiver, via. the headphone output, to another receiver with the bass turned all the way up and the treble all the way down on the second receiver. It works better than you might think but I am at work on an amp for the FR that will include an active crossover for the woofers and the subwoofer.
I found a pre-made pine table top at Lowes and affixed this to the top and added a base plate. I will add small feet later.
The completed speakers received a couple of coats of Minwax stain and several layers of Teak Oil. Being my first woodworking project of substance I made some mistakes in the process but the increase in SAF is significant.
You will notice the "second fireplace" behind the left speaker. This is a subwoofer I built to replace the 8" AR sub that I had been using. I modified the plate amp from the AR slightly to decrease the low frequency rolloff that was built in to protect the little 8" driver. It now has significant output to below 20Hz.
I took the wooden parts of a defective electric fireplace that I picked up for $5 and installed a closeout 12" paper cone woofer from Parts Express (no longer available) that had perfect parameters for the 5 or 6 cubic foot sealed enclosure that results. It is a vast improvement from the AR.
I am pleased with the results so far and am sure that a proper crossover will make it even better. Due to the simplicity of the system upgrading the FR drivers to something better is easily done.
Some day an architectural tapped horn should replace the fireplace sub.
Hope this doesn't qualify as too much information.
mike
