denniswilson
Well-Known Member
I have a Technics SL-1200 MKII. Does anybody know what type of oil I should apply to the spindle?
Thanks alot
Thanks alot
My Technics owners manual states: "Apply 2 or 3 drops every 2,000 hours of operation. Use SFW0010 oil (not included)."
any lite machine oil, 3 in 1, sewing mach, all at local hardware. No need to spend more than a couple bucks. It's just oil.
The only issue I see with 3 In 1 is that over time it tends to gum up then harden. That's the reason I bought the specified oil from Technics when I bought the deck.
Ron
OK Guys, Thanks
I have some SINGER sewing machine oil in the house. It says on the bottle that its mineral oil. Its clear and very light weight. I'll use that..
Thanks !! :thmbsp:
And then over how much time would it take for it to harden would be the next question. If it's 10+ years, that's not a bad deal.
Apparently there was also a similar discussion on Audiogon.
Some on Audiogon have mentioned using Mobil 1 5w30 for its synthetic properties and others have used regular sewing machine oil.
No. Motor oil is correct for belt drive platter bearings. Sewing machine oil is for the Technics DD. Two completely different situations.
Just curious...whats the difference
