#1
New Mc SACD piece!!
The MCD500 SACD/CD PLAYER !!!
$6500 dollars of sheer heaven and also has 2 selectable digital inputs for use of outside digital sources like the MS750 or other device!!! SHIPPING IN AUGUST!!! WOW ![]() ![]() ![]() ![]() |
#2
Well I guess that ends the drama
#3
We need to see it!
Quote:
![]() Pete |
#4
This is just what I was looking for. Lets hope the DAC's are somewhat close to MDA quality.
Jim |
#5
Coolness.
![]() So now we know and can sorta relax a little. Did you hear is it 2 or multi channel?Carl |
| Audiokarma |
#6
Introducing the MCD500 SACD/CD Player with Digital Inputs
The new McIntosh MCD500 SACD/CD Player combines exceptional sound quality and flexibility with a unique parallel DAC topology that sees four 24-Bit, 192 KHz PCM/DSD digital to analog converters per channel arranged in a differential balanced configuration. The data accuracy resulting from this approach allows a more faithful reproduction of the analog waveform for very low noise and distortion with the kind of transparency associated with a live musical performance. Additionally, all internal clocks are generated by a phase-locked loop generator for stable, low jitter operation. The sonic benefits of the MCD500 are not limited to internal CD and SACD playback. Two selectable digital inputs are provided for use with external digital sources like the MS750 Music Server. Indeed, the MCD500 has the potential to improve the sound of any 2-Channel digital music source. The drive mechanism features a die-cast, wrap-around chassis with a steel top cover to dampen resonances for silent operation. A new, die-cast disc tray runs silently on a single steel bearing providing an opulent look and feel to the operation of the player. A premium linear power supply features an R-Core transformer and nested regulation. The MCD500 analog stages employ a differential balanced topology for wide dynamic range and the best possible fidelity. Both fixed and variable outputs are supported and a dedicated high-performance headphone amplifier with ¼” jack is provided. The MSRP of the new McIntosh MCD500 is $6,500 (U.S. & Canada). Initial shipments are scheduled |
#7
Although too expensive for my pocketbook I am real happy to see McIntosh supporting SACD in this day and age of Blue-Ray, very reassuring at a time when all I hear is that SACD is a dead format, perhaps very strong support from European and Japanese markets for Hi-Rez SACD is one of the reasons that SACD refuses to pass away.
I am primarily into classical where SACD is the format of choice. Vahe |
#8
Quote:
That is exactly what I am looking forward to hearing about.... I wonder what Denon model it is close to ?
__________________
MC-501 (2), MC-7106, MX-119, MS750, modified Denon 3910, Museatex Bidat DAC (updated), VA Mahler, Oratorio and Waltz. REL B1 sub. RGPC 1200s, 400pro. Hydra 2 & 6, 2nd system: C712, MC-7270, Museatex Bitstream DAC (updated), LSA1 Monitors |
#9
That's NOT what I was expecting or hoping for. What's the point of it only a few months after 301 and what's the difference between 'em? I mean there are gaping holes in Mac lines like an affordable fully balanced pre or new multi-chanel integrated and we get another SACD player?
__________________
MCD 301-6900-JBL L150 |
#10
Digital inputs. Stroke of genius. Use it as a DAC for all sorts of things. Sonos for example. Hook up your low budget Blue Ray player to it.
__________________
(2)2102 Power Amps, C2200 PreAmp, MVP851, Audio Research CD7, Audio Research DAC7, Sonos, Vandersteen Wood Quatro Speakers |
| Audiokarma |
#11
I would really like to see some pictires. I'm a little disapointed as I'm not interested in a "player" right now. I'm sure others will find use with it. I just can't get away from lossless music formats on my PC. Gotten too lazy.
Curious to hear some official comments on its internal DAC vs the MDA1000. jc
__________________
McIntosh MCD500 MC1201 (x2) MC275V (x2) XRT1K Ashly EQ and Active XO, QSC, Crown amps and Transcendent T16 on big horns McIntosh MC250 Dewicked x 2 |
#12
MCD500 is a good move. McIntosh needed a mid-range CDP/DAC. This hits two birds with one stone.
Anyone has pictures? |
#13
I hope that it is also a pre like the 201/301..
#14
#15
This is exactly what I was looking for. The unit is supposed to have 8 DAC's, so I am hoping the quality is "close" to the MDA. I can sell both my Esoteric and my external DAC and still keep the C-200 if I want too. This is less expensive than a Wadia and about $40k less than the MBL SACD and seperate DAC.
| Audiokarma |
| Thread Tools | |
| Display Modes | |
