I just found this pair of ADC 303a at an estate sale for $20. I've looked at a lot of posts in AK about these speakers. Apparently the older 303a's like these are 8" woofers and there were later 303ax's which were 10", not to mention other differences. It appears one of my cabinets "works" (I didn't 'extensively' test it) and the other measures a dead short across the speaker terminals. They're coming open- I'm just trying to figure out the best way to do it. The grills are not coming off- and I don't want to tear them up. It sounds like the drivers are mounted from the inside, anyway. (6/23/19 Edit: The woofer is mounted from the rear. The tweeter is mounted from the front.)
In a post about 3 years ago, Philliam (PT) says that he opened the backs of 303ax's by cutting 1-1/8" inside around the outside edge of the box. I would really like to see photos of this, or any other repairs you guys have made on this model, or any other speaker that wouldn't open by civilized methods.
I've also had someone else tell me they would also cut the entire back out, but at 3/4" around the edge- the same dimension as the thickness of the wood. Then, before putting the same backs back on, install bracing around the inside and re-install the backs onto the bracing with 'cabinet putty' and screws after repairs were complete.
What do you think my best options are?
Brian
Brian
