if it was new, return it. i've done it a bunch of times to bigbox stores and local indie stores, without them questioning it. buy a new copy and if it's the same, keep doing it. if it's a local store, ask them to open it up and try it out in shop before you take it home.
if it's used and/or ebay etc, you're probably out of luck. buy a new copy and hope for the best.
i've tried the iron in between two bath towels before, just playing around. it got a pretty warped record fairly flat. i should have stopped there, but i jacked up the heat and made it even worse then when i started. i think the key to this method is LOW LOW LOW heat. the lower the better, and just keep going over the towel. i even double or triple folded the towel, but i did work.
