Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Dollars and Sense
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 09-07-2008, 01:35 PM
MystikCabs's Avatar
MystikCabs MystikCabs is offline
tubes & tonewoods
Harman Kardon hk 330i
I have a Harman Kardon hk 330i stereo reciever. Just wondering if it's worth hanging on to for tunes out in the garage or is it better than that?
  #2
Old 09-07-2008, 01:46 PM
jpdylon jpdylon is offline
non-active member...
The 330i was not one of the better designs. They run very hot and usually need some resoldering. Also, the driver stage in the amplifier uses very underrated transistors that can easily fail. The tuner is OK, but really overall there is better out there from HK.
Unless you can get it for a song I would pass IMHO.
__________________
Jordan
  #3
Old 09-07-2008, 02:04 PM
Sir.Byrd's Avatar
Sir.Byrd Sir.Byrd is offline
Custom Audio Designer
I had a problem with the transistors in the driver stage of my PM-640 and Ecluser and Terra1 worked on a procedure to replace the transistors with a higher rating to reduce heat. I also have a 330i, should work the same on it.
  #4
Old 09-07-2008, 02:06 PM
Sir.Byrd's Avatar
http://www.audiokarma.org/forums/sho...d.php?t=169829
  #5
Old 09-07-2008, 02:52 PM
MystikCabs's Avatar
tubes & tonewoods
Quote:
Originally Posted by Sir.Byrd View Post
Hmmm, good to know, thanks!
Audiokarma
  #6
Old 09-07-2008, 05:04 PM
terra1's Avatar
terra1 terra1 is offline
AK Member
I actually didn't replace any transistors on the PM640 because they didn't have a complete set at Fry's.
So, I just replaced two original 56 ohm resistors with 1/4 watt 220 ohm resistors I got at Fry's. A pack of 4 cost 95 cents. After that the temp in the PM640 driver heat sinks dropped from about 69 degrees centigrade to 38-40 degrees centigrade.
I also have an HK 330i and it doesn't seem that hot at least not as bad as the original PM640 before replacements. The heat fins on my HK 330i measure about 29-33 degrees centigrade, and the heat sink on the single transistor is about 51-57 degrees centigrade at its hottest point.
But up to you if you want to get something better. I would try it while you have it though.
It's one of the sweetest, warmest sounding receivers I have and nice detail too.
The only shortcoming is it sounds better than it's pillbox looks. You may want to adjust the amp's idle current to optimize it. I think I noticed a more 3D richer sound.
http://manuals.harman.com/hk/Service...k330i%20sm.pdf
If you do some research, vintage HK can be a crapshoot. I passed on an HK 330B awhile back because of tuner distortion (not just static) during a demo. The seller later reflowed the solder and said it was fine, but I still passed based on a combination of price, cosmetic condition and didn't want to waste another trip.
  #7
Old 09-07-2008, 10:02 PM
Sir.Byrd's Avatar
Quote:
Woops I misspoke!
  #8
Old 09-07-2008, 10:41 PM
terra1's Avatar
AK Member
Woops I misspoke!
Not a biggie since we were talking about replacing the transistors too.
It's just that as I said, Fry's was out of some transistor replacements. So I at least replaced the resistors as recommended by ecluser. That alone brought the temperature down.
So I'm not that concerned or in a rush to do the transistors.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
