When you type in your reply, it is in a "reply to thread " box that fills a typical screen.
Look below the "submit reply" button in that box, and you will see another box just like the "reply to thread" box, titled "additional options".
Right bang in the middle of that "additional options" box is a button "Manage Attachments".
But back to the 3900...
On the power supply, pin 17 has ac coming in which is fed to a voltage divider (R1 6.8k, R2 27k) a Diode (D1) and a capacitor (C1 2.2uf ) and then the capacitor's voltage goes off the power supply board on pin 4 and comes into the power amp board on thew amp board's pin 8.
The polarity of D1 and C1 can be reversed from what is marked on the board !!
The older factory configuration where the polarities conform to the markings on the board, generates a negative voltage on pin 8, which drives an npn transistor (2sc or 2sd number) on Q139 in the protection circuit on the amplifier card.
The newer version generates a positive voltage by reversing D1 and C1, driving a PNP transistor (2sa or 2sb) in the Q139 position.
The reason I bring this up is usually C1 (2.2uf) shorts out, and the protection never connects the speakers to the amp.
Unfortunately that cap is a beyotch to get to on the power supply card.
It is right under the corner of the transformer mounted on the board, and the diode is right below the cap, with the band pointed away for the older negative voltage and towards it for the newer positive voltage.
I don't think it's possible to loosen the board mounts, and swing it down far enough to protrude below the bottom of the chassis.
As for the destroyed transistor, is it a LITTLE one, or is it about 1/2 inch square? Is it more towards the center inch or two of the board (protection) or the 4 inches or so to the left or right.
If you look at the manual carefully, on the pdf manual, page 27 (of 47) there is a layout of the amp board that should help identify the transistor's name.
