DAT Sony DTC-790 problem
dukasound
Hi
After a long time I try to use my Sony dat but after switch on and put cassete on display was message CAUTION. After this I cant remove cassete out and none command cant work.
I remove it with manual way, rolling pulley who open a dat's door.
I watch manual and after translating to english (this was on german) I decided can be problem with humidity (for example). One day dat stayed switched on and I used hair fan to slowly dry inside of dat.
This morning I try but it's the same.
Does anyone can help me. What can be problem.
Thanks in advance
Duka
Usually the Caution indicator means there is a problem with the transport, so it could be a sticky micro switch, bad sensor, worn belt or hardened grease ect. In my experience, any electonics with a complicated mechanism, if not used in a while, could use a good relube to get it going again. Other than that, I really couldn't say what it can be. Good luck!
A common problem with the Sony D7 was that the grease would harden. Careful clean and regrease sorts it. That's where I'd start!
Thank you for that info, it helped me fix my "caution" message problem! All I did was use a Q-tip to move the tape rollers to free up the drying grease.
