:worthless
I want to see what a rabid squirrel cork mat looks like
I've made a few myself.
the best method I found was this process.
1) cut out a rough 13" x 13" square
2) iron it, not too much steam, just a little.
3) let it dry
4) punch out center hole, measure it.
5) take your platter off, and sit the mat on it.
if your platter has a solid center spindle that's attached, then set it on a box with a hole in it so the bottom spindle can sit nicely.
for mine the platter just has a hole in the center, so I grabbed the sub platter from my TD125 flipped it upside down to keep the cork centered.
6) with a fresh exacto blade, the 1" wide snap blade box cutter type, cut into the cork on one of the sides at an angle, and slowly work your way over a few inches to the platter.
you have to maintain a careful angle of the blade so the edge never cuts into the platter, but glides along the platter just behind the edge. you want the blade to be vertical, and you want to work it back and forth a bit to ensure that you are cutting the cork, as it tends to want to rip.
7) work your way carefully around the platter, and within a matter of minutes, you will have a freshly cut 99% precise cork mat, made to measure your TT.
