Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 11-12-2008, 05:14 PM
Styx_II's Avatar
Styx_II Styx_II is offline
The Grand Illusion
Kenwood KD-2070 Questions?
I recently picked up a 2070 which is in good condition. This model has an interesting anti-skate mechanism which I'm not familiar with. I need some direction on how it works and what it should be set at.
It came with an Empire cart #5000 HPT and a 239 DEX stylus (.75 - 1.5 grams tracking pressure)
Any help would be greatly be appreciated.
Also it came with an universal headshell which I'm wondering if I should change/upgrade to something else. Any advantages?
Thanks Gang,
__________________
Styx
Harman Kardon-3490, HK Bridge II, HK BTA-10, Polk TSX-550T's, Polk PSW 110
  #2
Old 11-12-2008, 06:59 PM
hakaplan's Avatar
hakaplan hakaplan is offline
Needs professional help
I'm sure someone will chime in, but you can download the manual for the KD-2077 at vinylengine.com, which is the identical setup and read exactly how to do it.
The headshell is fine. The cartridge is very good--definitely worth using, but unless you're sure the stylus is okay, it's better to get a new one.
If you don't have the alignment gauge, I'm pretty sure that you keep the cartridge square in the headshell and set the measurement from the stylus tip to the end of the rubber washer to 50.5mm.
__________________
Howard
  #3
Old 11-12-2008, 09:19 PM
Styx_II's Avatar
The Grand Illusion
Thanks for the lead on a manual......perfect! That's what I needed.
__________________
Styx
  #4
Old 11-12-2008, 09:29 PM
asoundhound's Avatar
asoundhound asoundhound is offline
Definitely Low-fi
you adjust the anti-skating by moving the wire to a different slot along the rod at the top of the tone-arm mount. closer to the counterweight = less, further from the counterweight = more. i believe it is in one gram increments. i'd put the wire into the first notch from the counterweight and track at about 1 1/4 grams. it's hard to tell from the photos, but i'm not sure your weight is original. the wire appears to be.
__________________
sansui au-7900/tu-7900, mcs 6700, nak cr-1a, denon dcd-1290, new large advents.
  #5
Old 11-12-2008, 09:31 PM
Definitely Low-fi
oh yeah, nice cartridge!
__________________
Audiokarma
  #6
Old 11-12-2008, 09:50 PM
Styx_II's Avatar
The Grand Illusion
Quote:
Thanks. I don't know if the weight is or isn't original. The previous owner said everything was original (-the cartridge). I didn't believe him after see the headshell but the manual I just downloaded shows the same one.
__________________
Styx
  #7
Old 05-16-2010, 08:44 PM
luckybaer luckybaer is offline
n00b
I just went crazy and won one of these Kenwood KD-2070 in an auction on eBay. It looks like a really nice turntable, and it reminded me of some of the turntables I saw when I was in college in the early to mid eighties.
Anyone have any thoughts on this turntable?
  #8
Old 01-15-2015, 10:31 AM
audiomagnate's Avatar
audiomagnate audiomagnate is offline
AK Member
It's a great table! I just brought one back to life and I love using it. That "Hurst Shifter" control is awesome. I like it so much I may give it an exotic veneer treatment. Mine had one channel out and the speed was all over the place. Here's what I had to do to get it working properly:
1. The transformer isolation bushings on mine had rotted away, so I made new ones from fresh foam and 3/4 inch shrink tubing.
2. Adjusted and de-greased/re-greased cueing mechanism.
3. Cables replaced.
4. Deoxited the speed pot and speed selector switch.
5. Ordered new anti-skate weight.
Now it's dead quiet, speed is rock solid and I have a right channel. I slapped a Nagoaka MP-150 in it and it sounds very nice indeed, but the best part is slammin' into gear with that bad boy lever. Oh yeah!
__________________
Sources:Kromecaster/Tidal, Garrard RC88/4 w/GE VRII,
Xover:Gemini CX-1000
Amps:BGW 620B x 3(subs) Nak PA-7(mains)AU-505(supertweeters)
Speakers:JBL L200
Supertweeters:Infinity EMIT-R
Subwoofers:4 x 12" sealed,1 x 15" sealed
Surrounds:Pioneer Elite TZ-F700
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
