Synchro-bias
New ClassA
Hi All
I purchased a Technics SU-V85A from ebay, it has a ding i the front and needs a clean up, notice corrosion on the rca plugs ( i read around and got DeoxIT Contact Cleaner & Rejuvenator) Maybe i can also use the contact clearer on the speaker connects also i was thinking.
European Military ( i found this out after matching the model number with the specs from the service manual i downloaded.
(IHF'78)
Specs
Rated minimum sine wave RMS power output
20Hz - 20 kHz both channels driven.
O.003% THD 120watt per channel (8ohm)
CLASS AA ( the V85 is on the bottom)
http://img218.imageshack.us/img218/3724/p1050199ur5.jpg
http://img218.imageshack.us/img218/6182/p1060218td8.jpg
http://img81.imageshack.us/img81/9770/p1060204uo5.jpg
corrosion
(IHF'78)
Specs
corrosion
