Jeff's Class
Member
Was trolling a yard sale and came across these speakers, which I wound up dragging home. Manufacturer is Acoustic out of Van Nuys, Model 616. Couldn't find anything searching here or on the web. As you can see from the photos they are 3-way with internal crossover network and adjustments on the front. One woof (they're 8") has been replaced with what appears to be a cheapy Radio Shack unit, the other appears to be original but the foam is shot.
The cabinets look to be well made with thick particle board structure and real wood veneer, although it's been painted over with a thick coat (or two) of latex. I had to clean pretty carefully to be able to read the manufacturer labels on the back to get the model number.
Any info on these speakers and the manufacturer?
Thanks in advance!
Jeff
Thanks in advance!
Jeff
