Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 01-06-2009, 11:56 AM
Sansui Louie's Avatar
Sansui Louie Sansui Louie is offline
Curmudgeon
Opinions on JBL 2600?
Looking for some excellent smallish yet inexpensive (used) bookshelf speakers that are efficient and have a good low end response (for the size). What do you think of these?
  #2
Old 01-06-2009, 12:11 PM
RastaFish's Avatar
RastaFish RastaFish is offline
Where's My Mule?!
I had a pair of 2500's for a while, they were not that impressive to me. The tweeter was not as smooth as I like, and although they were fairly efficient (they were ported) the low end did not strike me as being any better than what I get out of my Minimus 7's. The 2600's may have a better low-end, however, as I think they are a little bigger than the 2500's that I had.
__________________
Technics SL-1200 M3D / Shure m91ed
California Audio Labs Icon CD player
Akai GX-F95 cassette deck
Kenwood KA-7100 integrated amp
SpeakerLab Seven's
  #3
Old 01-06-2009, 12:38 PM
Zilch's Avatar
Zilch Zilch is offline
Curve Junkie
Quote:
Originally Posted by RastaFish View Post
... the low end did not strike me as being any better than what I get out of my Minimus 7's.
Violation: Low blow:
__________________
"More data ... less wank ...
In relentless pursuit of truth, enlightenment, and the AudioKarma way...."
November 22, 1942 ~ February 4, 2011 R.I.P.
Audiokarma.org Member of the Year 2010
  #4
Old 01-06-2009, 01:10 PM
willhowl's Avatar
willhowl willhowl is offline
AK Member
Jbl 2600
Howdy,all. I am currently running a pair of 2600 with my Marantz 2015 and an Audiosource 10" powered sub. This combo sounds fine to me.
When I first got the 2600, I connected to a Technics SU-Z950 int amp &tried it out. This amp is an older rack system unit, have seen ratings of 100WPC. The combo really surprised me- very clear high-end, amazing bass- for a small speaker.Back into storage they went for about a year. When I moved, I needed a more compact system,so out came the 2015 & 2600s.
The 2015 pushed the JBL's well, but I wanted a more solid low end, and to ease the load on the Marantz...hence the AS sub.
The 2600s performance will depend (of course) on the room, power applied, and desired listening level. I feel confident saying that for a smaller room (bedroom, small office, etc.) and a decent source (20-25 W on up) they would work very well. Note: Deafening levels unlikely. They can play pretty loud, however. Strong point would be their clarity.
The strongest point, probably, would be affordability.(Hopefully) Mine were very resonable, mint, on craigslist. There seem to be a lot of these around, good deals should be easy.
Bottom line... I like mine just fine....I can't use my larger speaks right now,but these will do........willhowl
  #5
Old 01-06-2009, 01:25 PM
Curmudgeon
Well, according to the specs in the OM found at jbl.com, the 2500 and 2600 differ in freq response low end rolloff by about 25db, which is huuuuge, with the 2600 dipping lower, to around 50hz. So that might explain a lack of bass in the 2500's Rastafish had.
Willhowl, is the bass on your 2600's realistic and convincing enough for a small speaker, or does it sound lacking?
Audiokarma
  #6
Old 01-06-2009, 01:56 PM
willhowl's Avatar
AK Member
Fishing for Bass....
Hey,there Louie... Kinda a tough one...it's so subjective...(exit weasel phase)
I tried these speaks with high power quite a while back, but I was impressed with their low end. My recent use with 2015 left me feeling that there wasn't enough "juice" behind the woofs to produce fully at higher volume levels....also wanted to eliminate any chance of clipping from the amp, so I plugged in the sub.
I really feel like the 2600 bass is solid, and proportioned....with a little power behind them...So,the answer to your question would be "yes" (realistic and convincing)......and no,(lacking)..... close to weasel ville,here...
But... for a good size room at CONCERT levels...no,they won't rattle the foundation. How could they? 6.5 woof????.
I really like these,overall, consider them a very good value......if you find some cheap, try them....they are winners, for their size.... willhowl
  #7
Old 01-06-2009, 02:05 PM
Curmudgeon
Well, I'm looking at them for a small office, where I'm sitting no more than a couple feet away from them.
  #8
Old 01-06-2009, 02:16 PM
Andyman's Avatar
Andyman Andyman is online now
Scroungus Stereophilus
Location: 15 miles North of Canada, East of Grumpy. West of Kegger
FWIW, Kegger and I hooked up a set of J216s out in the garage to test an amp he brought over and were pretty amazed at the sound; they certainly didn't come off as smallish bookshelves and sounded MUCH bigger than they are. I'm seriously thinking of keeping them out there, but may move them to the bedroom to reclaim some room up there.
__________________
"Do or do not. There is no try"
- Yoda
  #9
Old 01-06-2009, 04:32 PM
jetblack's Avatar
jetblack jetblack is offline
Love Those Tunes
S.L.,
I originally bought these to hook up to a 'low end' Kenwood receiver for my system at work (more money in the speakers should work). I now use them as rear surrounds for home HT, hooked to MC402's.
They should work for what you need. 2600's are spec'd at 45Hz, with 6.5" woofer. You mentioned "low end response". Food for thought, JBL also offered:
2-way 2800, 8" woofer, 40 Hz, 89 db sensitivity
3-way 3800, 8" woofer, 35 Hz, 89 db sensitivity
3-way 4800, 10" woofer, 35 Hz, 91 db sensitivity
__________________
MX136, MC501s, MC402, MCD500
RtR 300Ds, JL Fathom F112, Mirage OM-C3, JBL 2600s
Dual CS 606, Ortofon 2M Black
Tandberg TD20A, Harmon Kardon HK 400xM
PPP, Power Port, WW Ag Eclipse ICs & Speaker Cables, WW Ag Electra PCs
  #10
Old 01-06-2009, 04:36 PM
kbott's Avatar
kbott kbott is offline
AK Member
my stepson has a pair in his room powered by a marantz 1120 integrated.. soundwise to me they are just eh but he chose them over a pair of cerwin vega d-1 which i felt blew away the jbl's on the low end 30 Hz for the vega's vs 60 on the JBL's
I also find the tweeter on the JBL to be very bright it really needs to be tamed with the tone controls. I've since added a passive sub to his room which seems to augment things nicely
personally I would only buy them for no more than $10 (because you'll probably need to refoam them as did I) only to sell them for no more than $30-35. To keep them - no.
in that size area I would try and find a set of used Pinnacles I've had three pair so far and I'm most impressed with the pinnacle PN-7's
__________________
Audiokarma
  #11
Old 12-07-2010, 11:48 AM
SkyLounger's Avatar
SkyLounger SkyLounger is offline
AK Member
Reviving an old thread... I was looking for specs myself since I was given a pair of 2600 last week. I have to replace both woofers though, and since the tweeters are reported to be shrill, I'll try replacing them with a pair of soft domes I have sitting on the work bench...
I found an OM on the JBL site for the whole series, so here goes:
http://www.jbl.com/resources/Brands/...00-4800_OM.pdf
__________________
Thorens TD124 w/SME 3012 S2 & Ortofon 2M Bronze | Cambridge 851A, 651C, 651P | Chord Chordette Qute EX | Sonus Faber Grand Piano Home
  #12
Old 12-07-2010, 12:08 PM
GordonW's Avatar
GordonW GordonW is offline
Speakerfixer
Replace them, or refoam them? Most of the time, they only need new foam surrounds. BTW- there is a foam surround made specifically for these... it's easy, when you have the right ones.
Regards,
Gordon.
__________________
“My definition of too much horsepower is when all four wheels are spinning in every gear.”- Mark Donahue
My AK Gallery Photo Page: http://www.audiokarma.org/gallery/sh...00&ppuser=1240
  #13
Old 12-07-2010, 12:29 PM
Rome's Avatar
Rome Rome is online now
Holsum Honey Buns
I have a pair of these & they are a wonderful sounding speaker.
Rome
__________________
"Arm Yourself With The Weapon Of Common Sense" -- Rome
Iry Primate
  #14
Old 12-07-2010, 01:21 PM
sealy's Avatar
sealy sealy is offline
AK Member
A good first speaker for neophytes. However, there are a lot better offerings out there.
__________________
Never rub another man's woofers.
  #15
Old 12-07-2010, 04:32 PM
SkyLounger's Avatar
AK Member
Quote:
Obviously, but I'll probably use them as rears for an HT setup, after playing with them a bit... after all, they were free.
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
McIntosh Cabinets
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Audio Doctor
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
