secondslc
mmmmmarantz
This is a story about an unassuming amp and tuner that I picked up some time ago at a local thrift store. Its what got me to give JVC a second look and buy their mightly a-x9
I really liked the looks of the integrated amp with its meters. Looked serious enough, was heavy, and had a DC badge on it. I was going to use it in my garage as it looked kinda filthy.
And then I opened her up.
:yuck:
I vacuumed it up as best as I could and powered it up. No static in the controls, and everything was working perfectly. I decided it was worth cleaning up some more and got the faceplate very presentable. Thats when I admired the quality of materials. Thick aluminum faceplate, steel chassis, metal knobs, and quality feeling switches. Cleaned up nice
Then I started listening to it on some KLH 23s in my basement, and it sent the sansui out to garage duty. VERY controlled bass and big sound. This surprised me since KLHs are power hogs, but this JVC controlled them nicely and sounded pretty darn natural. The graphics equalizer made big changes in the sound, but leaving everything flat sounded best.
So after a few months of use, the left channel started cutting in and out. I knew it was a dirty pot, so I put it off till I could replace the unit and do a full cleanup and re-cap.
And a full clean up I did.
Thats the whole thing sans chassis.
I decided to really get in there and get rid of all that nasty dust. The unit was amazingly easy to get all apart, and well thought out. Alps switches and pots were used throughout, as well as good quality Elna boards and caps. Then I looked at the amp section and was shocked to find "darlington power packs".
There is nothing wrong with them as long as the circuitry is properly implemented. I think this integrated is one of the better units using the darlington packs. They're rated at 50wpc. JVC rated this unit at 45 wpc, so it was a good match.
I then proceeded to work on the unit. I washed all the boards with proper cleaners, re-capped everything, and completely cleaned the chassis. How does it look? I'll post pics as soon as my camera charges up again. I got this shot in however.
How does it sound?
Its not giving up much to its bigger brother the a-x9, build quality is similar too. This is NOT meant to bad mouth the 9 as its an amazing unit, its just that this integrated is definitely from the same family.
In conclusion...give JVC a look, you'll be glad you did.:thmbsp:
:yuck:
How does it sound?
