Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Solid State
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 01-17-2009, 09:05 PM
EchoWars's Avatar
EchoWars EchoWars is offline
Roland's Evil Twin
Kenwood L-09M
Since I've rebuilt five of these amps in the last couple of months, I thought I'd share a bit of what I've learned about these amps.
Built as monoblocks, the L-09M is the most powerful amp ever built by Kenwood. Sold for two years in '79 and '80 (from what I remember), the L-09M is rated at 300W output and retailed for $700 each...so setting up for stereo meant coming up with $1400! This also makes it Kenwood's most expensive amp, by far.
Here's a peek inside:
The L-09M is a fully DC-coupled design, with a FET differential input stage, current-sourced and cascoded. Nothing too unusual there, but this stage feeds a PNP differential VAS, which feeds another NPN differential for the bias stage. The output stage is an unusual cascoded setup, probably chosen to increase the reliability of the output devices (stock devices are Sanken 2SC1116 and 2SA747).
The rail voltages for the output devices are what raise an eyebrow: Schematic calls out +/-106V, and I usually measure about +/-110V with no load! The L-09M does this with a separate transformer for each rail!. I can't recall ever seeing this done before. These transformers feed a bridge rectifier, and then go to two 18,000µf 120V caps, which provide power for the entire unit...there are no extra windings in the power transformer and no regulated voltages in the amp (save for the 28V zeners for the FET input stage). I like this simplicity...regulators are always a trouble spot in vintage gear.
The amp has a front panel switch, which - through a relay - allows two sets of speakers to be connected. You are not allowed to run both simultaneously...choose 'A' or choose 'B', not both. There is also an ususual front panel attenuator, which, through voltage-divider resistors, allows reduction of the incoming signal at -3db, -6db, -9db, -12db, and ∞. Due to its limited range, it is a true attenuator, and not a volume control (thus driving the amp directly from a line-level source without its own output control is not feasable, or recommended...given the power at hand). The meter circuit has three ranges: 1x, .1X, and .01X, which would correspond to 300W output, 30W, and 3W. Very nice, but don't rely on the meters for true readings. While the L-09M meters are better than many, accuracy was not a large design priority.
The L-09M is designed to be powered up either by an external signal voltage, or with a flip of the rear panel switch, powered up normally with the front panel switch (both the L-07C and the L-07CII can provide this voltage through rear panel jacks, so powering up the preamp will power up the amplifiers). Either way, the incoming current surge is carried by an Omron LY-2 relay, so the power switch is unburdened of this heavy power-on transient.
I have found no real weakness with the design, other than the active cooling, and the only reason I call it a 'weakness' is that any time you're moving air, you're moving dirt, and thus an occasional blasting out of the fan and heatsinks with compressed air is a very good idea. Anyway, the heatsink assemblies are not terribly large, but are oriented so that together they form a tunnel with the 100VAC fan mounted at the right rear of the chassis. This fan runs continuously, limping along at a low, nearly noiseless speed under normal operation through a reduced voltage via a large power resistor on the startup/fan board. If run hard enough for long enough, there is a thermal switch mounted on the heatsink designed to trip at 70°C, and this shunts two power resistors on the fan board for increased voltage to the fan, which kicks it into its high-speed mode (which is also admirably quiet). The thermal switch seems to have little hysteresis, and as soon as the temp drops below 70°C, the fan drops back to idle mode. Under normal operation, you will be hard-pressed to get the fan to kick into high-speed mode. Takes about 45 minutes of 50W output to get the amp hot enough to trip this switch.
(Note about the fan: Because Kenwood used a 100V fan, they also sized the voltage limiting resistors on the Startup/Fan Board appropriately. Two of the units here had fans with somewhat worn bearings, and needed replacement. The stock fan is 119mm x 28mm, and the maximim allowable width is perhaps 32mm, so the 'standard' 119mm x 38mm fan is a no-go. I spent days looking at various 119mm fans, and the only suitable long-life replacements were a couple of fans from ebmPapst...a maker of very good, but very expensive fans. I chose the ebmPapst 9906 fan, which is a 119mm x 25mm 115V ball-bearing fan, and cost a bit over $40 each. The stock voltage limiting resistors should be replaced for two reasons: one, Kenwood mounted the stock resistors flush with the PC board, and this is slowly burning up the board. Two, the new 120V fan will spin too slowly with the stock resistor values. The stock resistors are 1.6K @ 10W, and 430 ohms @ 7W. These should be changed to 1.2K @ 12W and 400 ohms @ 8W, and the replacements should be the hollow enamel type, such as the Ohmite B8J and B12J series. These resistors shed heat very quickly, and prevent burning the board and melting their own solder connections. Even if the stock fan is working well, I'd replace the stock resistors with those mentioned above.)
Although Kenwood rated the amp at 300W into 8 ohms, that's an extremely conservative number...of the five amps I've rebuilt, the one that measured the lowest hit 408W into 8 ohms...most were between 410 to 420W. (I have not tested power into 4 ohms, but I will eventually do so and update this thread.) Measured distortion is very very low, and on a properly functioning unit will be around 0.0035% @ 300W (1KHz). Obviously, the L-09M has the power to drive most any speaker you can think of, with the possible exception of something like 1 ohm Apogees. The amp has an 'official' rating of 4 to 8 ohms, but I would not hesitate to drive difficult loads such as the Infinity speakers using Watkins woofers.
One other thing...the distance from center-to-center of the rack cutouts is a nice, standard 4". For my own L-09M's, I've bought some stainless steel handles and attached them to make the amps easier to lug around. And they look cool too. (Edit: the Omnia 8mm dia. stainess steel rounded corner handle is a nice match. Omnia model #9538-102. Many home improvement places online carry Omnia handle pulls)
Overall, I'm very impressed with the build quality and the design of these amps. Judging from what I see, reliability should be very high, and from what I hear, sonics are not compromised by any design shortcuts.
If you're looking for an amp with nearly limitless power, this is one to consider. Not everyone needs 400W of power, but a lot of us want it regardless. The nice thing about it is, you can have all that power without sacrificing finesse. All you need are a pair of these.
__________________
"Any dangerous spot is tenable if men--brave men--will make it so."
- John F. Kennedy, Radio and Television Report to the American People on the Berlin Crisis.
July 25, 1961
  #2
Old 01-17-2009, 09:17 PM
M Jarve's Avatar
M Jarve M Jarve is offline
Audio Geek and NGE Freak
Whatever BPC they produced later in life, the L-series will stand as some of the best gear out there period. From what I understand, the L-09M was designed/built by Accuphase, as were the L-07M and L-05M, along with the L-07C. The only one not done by Accuphase, if I have my information correct, was the L-08M/L-08C, which were an all-Kenwood/Trio product.
__________________
/Mike
+ diy qls-3 clone + harman/kardon hk775 x4 + musical fidelity a3cr + sony cdp-707esd + audio power industries +
  #3
Old 01-17-2009, 09:23 PM
Switchblade Switchblade is offline
AK Member
These seem to be pretty hard to come by in my neck of the woods. Do they all require rebuild at this point in time, or is it a case by case basis?
  #4
Old 01-17-2009, 09:29 PM
nojmplease nojmplease is offline
AK Member
Talking
The L-09m's are surely amplifier gods amongst men.
Boy, these sure look familiar...
You should put up some kind of a demonstration video (on Youtube?) once you have these restored and hooked up to some serious speakers. And honestly, to anyone who wants amplifier perfection, you'll want Glenn's restored units. They might just last a lifetime.
Just watch out for those noise citations...from neighboring states.
  #5
Old 01-17-2009, 09:34 PM
Spalls's Avatar
Spalls Spalls is offline
Making up for lost time
Thanks for the post, EchoWars. Another great tutorial on AK.
__________________
AR SP-3A-1
Onkyo M-504
Denon DCD-1500 II
Technics SP-25, Grace 707 Mk. II, Grado Blue
IMF TLS 80
Audiokarma
  #6
Old 01-17-2009, 10:03 PM
EchoWars's Avatar
Roland's Evil Twin
Quote:
Anything this old should have electrolytics replaced. The L-09M is pretty straightforward, EXCEPT for the two large power supply caps. 120VDC caps have seemingly gone away, and the next step up, 160VDC, usually means a cap too large to fit in the squat enclosure. We put together a group buy a while back for some caps that would fit, and I still have a few of the expensive bastards left...
__________________
July 25, 1961
  #7
Old 01-17-2009, 10:04 PM
avionic's Avatar
avionic avionic is offline
Aim High !!!
Location: Fort Dodge, Iowa -Northern end of"tornado alley"
Glen . Is there a filter on the front end of the cooling channel?
__________________
Bridged Yamaha B-6's l C-85 l PF-800/DL-160 l CA AZUR 740 l
NS-1000M's
Keep it pithy!
RET USAF 1978-1998
"In Artie we trust"-- PPP
  #8
Old 01-17-2009, 10:09 PM
EchoWars's Avatar
Roland's Evil Twin
Nope. There's room to fit one in front of the heatsinks, but you'd have to remove the top cover to gain access to it. PITA. The ideal solution would be to cut a slot on the top cover to allow removal and replacement of a filter without taking the cover off. No, I won't be attempting that any time soon.
__________________
July 25, 1961
  #9
Old 01-17-2009, 11:01 PM
JBLKRAZEE's Avatar
JBLKRAZEE JBLKRAZEE is offline
AK Member
Quote:
Agreed. VERY informative, and very much appreciated.
__________________
" Turn that DAMN thing down or I'm calling the Cops!"
  #10
Old 01-18-2009, 11:27 AM
totem's Avatar
totem totem is offline
AK Member
Thats one Kenwood I was hoping to see an EW rebuild/review of Thanks.
__________________
I'm wearing the same skin, I take it all on the chin.
Audiokarma
  #11
Old 01-18-2009, 11:50 AM
theophile's Avatar
theophile theophile is offline
Pheasant Plucker.
Quote:
Firstly,thank you EW,for another worthy addition to the collective knowledge datbase.
These are the types of posts lacking far too much these days.
M Jarve,
G'day.
I said much the same thing(though I have no reason to know whether it's true).A very nice AKer called me on it,and said that Kenwood made and designed all their own gear.
My counterpoint was that the Japanese Majors had no trouble approaching other Japanese Majors to make/design items for them,when it suited them.My other point,was that since Kenwood were part-owners of Accuphase,it made sense that they would use their subsidiary to design/make their up-market pieces.
May I ask where you got your info about Accuphase's involvement with the 'L' Series?
Was it TVK?
__________________
Turntable/Tonearm: Yamaha GT-2000/YSA-1
Cartridges: Stanton 980 HZS or The Voice
Phono stage: Simaudio Moon LP 5.3
Line Stage: Hornshoppe 'The Truth'
Speakers: KRK Expose E8B Active Studio Monitors
  #12
Old 01-18-2009, 12:00 PM
marantzfan's Avatar
marantzfan marantzfan is online now
__________________
Main: Bottlehead BeePre, Eros and Paramounts v1.1 300B, Mac Mini with HQPlayer,
Ifi Micro Idsd/Iusb/Gemini/Mercury, Thorens TD-124/Audiomods Arm/Ortofon 2M Black, Altec 604-8G Duplex/620 Cabinets/Markwart Crossovers, DSpeaker Anti Mode, Dayton 15" Subs
  #13
Old 01-18-2009, 12:02 PM
redcoates7's Avatar
redcoates7 redcoates7 is offline
redcoates7
Always nice to see an EW restoration post...especially when a couple of the amps in question are in my listening room
I can tell you guys, these were very good amplifiers stock, but after the full EW treatment they are really very special!
__________________
...so how many pieces of vintage Kenwood Gear constitutes a problem, and not a collection??
  #14
Old 01-18-2009, 01:46 PM
Inspiribomb's Avatar
Inspiribomb Inspiribomb is offline
Enjoy the journey
Thanks for the insight into the inner workings of this fine amplifier, Glenn. I really loved mine when I had them.
__________________
Logitech Squeezebox Classic
Marantz SC-22
Marantz MA-24
NHT W1 X2 + A1 X2 + X1
Condor Acoustic Design SC-3
  #15
Old 01-18-2009, 03:04 PM
MisterFishey's Avatar
MisterFishey MisterFishey is offline
Mostly Functional
Excellent writeup EW, thanks for the info! I love reading posts like this.
__________________
McIntosh C28 | McIntosh MC2505 | Klipsch Forté
Custom Linux music server | Sony SDP-EP9ES | Schiit Gungnir
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Analog Engineering Associates
Capacitor World
Okki Nokki
Hudson Valley Hi Fi
Vintage Home Audio
Organ Donor Parts
Parts Connexion
Wargos Electronics
Take Five Audio
Audience AV
Sound Stage Direct
Simply Speakers
Sonneteer
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
©Copyright 2002-2015 AudioKarma.org, All rights reserved.
