Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Dollars and Sense
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 01-20-2009, 10:16 AM
chrisjlaw's Avatar
chrisjlaw chrisjlaw is offline
AK Member
Snell Type E
I have an opportunity to pick up a pair of Snell Type E speakers from a local seller. Apparently they are in good cosmetic condition but woofers require refoamed. Seller is asking $100. Worth pulling the trigger? Thanks in advance for any input.
  #2
Old 01-20-2009, 10:40 AM
MAXZ28's Avatar
MAXZ28 MAXZ28 is offline
Bazinga!
  #3
Old 01-20-2009, 05:24 PM
lukiedog's Avatar
lukiedog lukiedog is offline
AK Member
The Snell Type E is a vintage audio classic and if you need them, would be an excellent buy at $100. The cone diameter appears to be right on at 6", so the generic 8" foam available from matelectronics and other cheap sources should work, BUT these Snell speakers have a slightly oversized roll, I know because I just overlaid a generic 8" foam onto it and it fell a bit short. I personally would look for and ensure that the proper foam is purchased to do the job right. I would be very selective as to obtaining these foams, the Snells are worth it and it would add to your resale value if you chose to unload them.
The person who posted this ad claims to have gotten new foam for them, I'd see if they were willing to part with the source, because they are clearly the correct type:
http://vancouver.kijiji.ca/c-buy-and...QAdIdZ97355966
I would be wary of eBay vendors unless they confirm that the roll is oversized and the correct one for your application. Many are selling "kits" that are just generic sized and may not be what you need.
You can refoam these yourself, that is an easy process with much info on this and other sites on how to do it properly.
  #4
Old 01-20-2009, 11:37 PM
HomerJSimpson's Avatar
HomerJSimpson HomerJSimpson is offline
AK Member
I'd get them at that price...
  #5
Old 01-21-2009, 10:53 AM
packrat packrat is offline
AK Member
Quote:
Originally Posted by lukiedog View Post
.... BUT these Snell speakers have a slightly oversized roll, I know because I just overlaid a generic 8" foam onto it and it fell a bit short. I personally would look for and ensure that the proper foam is purchased to do the job right. ......
I agree - I have a pair of Type J needing a refoam and the generic 8" foams have a roll that is too narrow. I've been looking for a larger roll foam but no luck. I also think that the 8 inch EPI and Genesis woofers also used this larger roll surround originally but many people (me included) refoam them with a typical foam - it works but I've measured the fs of my refoamed EPI woofers and it is not as low as the original specs.
At $100 I'd buy those E's.
Audiokarma
  #6
Old 01-21-2009, 11:57 AM
chrisjlaw's Avatar
AK Member
I contacted the seller of the Snell E/IIIs advertised on kijiji as suggested by lukiedog and asked where they obtained their foam surrounds. This was the reply:
"I didn't have mine re-done —it was done by my customer, so I don't know where he sourced them. I would try Vancouver Audio Speaker Clinic."
Looks like some more work will be needed to source the foams with the correct roll.
  #7
Old 01-23-2009, 07:52 AM
chrisjlaw's Avatar
AK Member
I contacted Snell re. new woofer foams. This is the reply:
"We don't have the refoam kits for our speakers and don't really
recommend it because of the differences in the materials used. We do
have a solution though! We have the woofers for the Type E series
available. We take crossover components and adjust them to match the
production woofer to the master reference E woofer. We include these
components along with installation instructions with the woofer. The
cost of the E series woofer is $149.00 each. We would need to know which
Type E speaker you have, either the E original,EII,EIII or EIV. If you
would like to talk or order the woofers you can call at the number below
or e-mail and there is an order form found on our website."
  #8
Old 01-23-2009, 12:38 PM
outlawmws's Avatar
outlawmws outlawmws is offline
On the Run
I have 2 sets of Snell Type E. Type EIII and Type E II; excellent speakers.
They have beaten many (37 other sets of speakers, still working on getting rid of the culls…) other speakers in A/B tests and I give the Type EIII’s slightly higher marks than the Type EII’s which are in use as my rears for my Surround system. The III’s are in dual use, fronts and main stereo speakers via a switch.
Refoaming works fine, the drivers are all Vifas, and I used standard speaker foam and it fit fine. YMMV depending on the actual maker of the foam.
__________________
- Outlaw
Main: 9090DB, Snell Type EIII's, Marantz 6100, TEAC PD-D2500
LR: Motorola tubes, EL84 outputs, , Dual 1019 TT, Sony CDP-CE105, Wharfedale Sapphire SP-89's and a 15" GV center in an infinite baffle
Home Office: Sansui 6060, Sony CDP-C305, Original Advents
  #9
Old 01-23-2009, 05:45 PM
lukiedog's Avatar
AK Member
I went the same route and got pretty much the same response:
Hi XXXX,
We do not do the refoaming of the Type E series woofers and do not have
any refoaming kits. We do have the woofers for all of the Type E
speakers. We tune each woofer individually to the master woofer and
include the tuned crossover components with installation instructions.
We would need to know which model of the Type E series you own, either E
original,EII,EIII or EIV. The cost of the E series are all $149.00 each
with shipping in the continental U.S. included. If you are interested in
ordering you can call at the number below or use the order form found on
our website.
Mark Malynn
Snell Acoustics Customer Service Department
(978) 538-6262 ext. 6273
Mon.-Fri. 7:00 AM - 3:00 PM EST
Clearly, one must re-foam the existing woofers, the replacement woofer prices are on the unreasonable side.
GeoAli on eBAy is advertising he has Snell foams. I put a mike to the front of the roll on my woofer (EIII) and got 18mm for the Snell and 16mm for the generic 8". You might want to contact him and let him know you are aware of the difference and to confirm what he is offering is the larger roll. The generic 8" appears to fit and could be used, but you would be changing the characteristics of the driver somewhat. I have used alternate foams without ill effect on some projects (Paradigm Titan), but I'd do my best to get the right ones before going that route.
The EPI 8", by the way, can be refoamed with generic 8" from Matelectronics (.99/ea last time I checked) and it is a perfect fit.
  #10
Old 02-13-2009, 10:46 PM
eedork eedork is offline
AK Member
I've got EIVs that I purchased new back in college. They are excellent speakers in my opinion. I have been very happy with them regardless of the type of music and gear I've used them with.
I've used them with 3WPC tube amps and beastly 200WPC SS amps. They also powered many keg parties and have done everything I've asked (which has been a lot) remarkably well. Just good all around speakers.
I probably won't ever sell them.
-Matt
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
