First off I didn't realize there was any action on this thread, somehow missed it..
Second the original Circuit I drew up came from the mods to the ASL wave 20's I did
and some of the choices made were based on what the amp had and available room.
http://www.audiokarma.org/forums/showthread.php?t=194959
Dennis has those amps now in service at his place doing bass duty, they do perform
rather well if I say so myself with I doubt the greatest iron, presently they are using
6829 Black Plate Ratheons as the driver/splitter tube in each mono amp.
When Dennis was to build his we were going to tweak the circuit and PS accordingly,
adding in an Triode/UL switch if the outputs he ends up with have UL taps otherwise
triode only as Dennis doesn't need more then 12-25wpc for his setup.
I was keeping the voltage low at the time as that's what the ASL was capable of, but
yes I also felt leaving it somewhat low would make the use of old (5881, 6l6G, 6BG6G)
tubes optional and could be cool as well.
I feel the circuit is very simple and performs well but also makes an easy first time DIY
build for Dennis that should yeild quite good performance with little to no tweaking.
Alright with that out of the way..
I have no problem someone making suggestions or alterations to the basic schematic.
It was kept simple and loop feedback free so anyone could build it an have work with
no issues or real test equipment for any specific output transformer being used.
(Thanks for the Triode/UL switch layout WOP, now I don't have to do it) Appreciated..:thmbsp:
Pentodes running in UL with a driver stage that doesn't have excess drive and has the
relatively low plate resistance of say a 12AT7 will not "need" loop feedback to perform
well, Triode definatly will not need it, if running Pentode you'll probably need it or some
other form of output tube based feedback design.
(this not a knock on anyone feeling the need or wanting to use loop feedback it's just
what I've found works easily with these type circuits and provides predictable results)
I recently updated and posted on Jay's (Urizen) thread what I would basically do when
not being tied to what the ASL amps had originally. (Posted that a few days ago here)
http://www.audiokarma.org/forums/showpost.php?p=2450781&postcount=76
At the moment there's no power supply here until we see what Dennis has in the power
tranny being used from the organ amp.
I'm attaching a supply that should work using the Triode Electronics ST-70 replacement
power tranny with solid state rectification for ease of build if someone wanted to use it.
(this would be for a stereo amp)
Also what I believe should work for a 6SL7 as the driver, someone would need to build it
and do some quick measurements then possibly tweaking of the drivers plate and or it's
cathode resistors to dial it in, but I bet it's pretty darn close..
(I try to keep the cathode of phase splitter 99v or less and the drivers plate to as close
as I can to 100v without making the splitter higher then the 99v I just said, SO the driver
will be at somewhere around 97.5 when the circuit is tweaked for the highest gain tubes)
The original circuit for the 12AT7 is set as that being the (Highest Gain) tube, BUT the
6829, 5965, E180CC can all be used with no adjustments needed. (others as well)
The heater/cathode voltage is 100v on quite a few tubes and in this case the tubes are
under that BUT if a heater voltage reference is provided would certainly be a good thing.
