Done ... mostly ....
Hello everybody;
so, I sprayed some Deoxit (not really, but the equivalent available at Altronics,
http://www.altronics.com.au/index.asp?area=item&id=T3069) on all the trimpots (potentiometers, VR1 through VR6 except VR3, read below) and made some 50 full back and forth swings; same done with the fine speed control, i.e., the front panel user accessible speed control. And yes, the turntable is working ok.
So, in my case that is all is needed; well, not quite.
There is a very high wow and flutter rate and when I touch the front panel speed adjustment control knob the speed varies visibly and w&f accordingly. So, I will replace the potentiometer on next Monday 17/10/2012 and if necessary also the VR1 - VR6 trimpots; hopefully not, because I really would like to avoid to setup the oscilloscope and make the necessary calibrations ...
Finally, I did not spray Deoxit on VR3 as it is sealed and on the service manual says to just turn it fully clockwise and that "in the future" will be replaced with a fixed resistor ... So, I did turn it fully clockwise, as strangely enough it was not!
I am attaching to this last post for now
1) the picture of VR1 (responsible for the 33RPM speed setting) and VR2(responsible for the 45RPM speed setting) after the calibration; you can see is visibly different than what it was before;
2) the picture of the front panel user accessible fine speed control potentiometer, where you can read 1KB; this translates to 1Kohm, linear. This is important, it must be "linear".
3) four pictures of the actual turntable playing an LP from the double album Saturday Night Fever
And, behind the camera .... Me Happy .... (not shown) ....
