tensleep
Addicted Member
I have owned this pair of JBL 4410 studio monitors since the mid 80’s. I purchased them new and have loved them over the years, although I have not always taken the best care of them. I had to put them away about 4 years ago because the surrounds had deteriorated.
As with many novice audio enthusiasts, I thought that the speakers would need to be reconed, which I couldn’t afford at the time. In addition, my youngest son had collapsed the dustcap on one of the 127h low frequency drivers through a hole in the grill cloth. These speakers saw me at my best and my worst during my 20’s and 30’s, so they definitely needed to be gone through.
Anyway, I first discovered the Lansing Heritage Forum, which eventually led me here to all of you fine Akers. After reading and studying, I realized that I could make these repairs myself. So, I started about 9 months ago by unloading the drivers. Other projects got in the way (privacy fence, two young sons, car maintenance, etc.), so these sat on a shelf until this month. I finally ordered all the parts I needed (Gorden W supplied the surrounds and dustcap), bought a bottle of Aileen’s glue, along with some linseed oil and turpentine, downloaded a tone generator, and proceeded to resurrect my babies.
Let me tell you, I had forgotten how good these speakers sounded. Not only that, it is very satisfying to correct some of the abuse I put these fine instruments through. Here are some pictures of the work as it progressed.
Finally, I still have to repair the grills. Most of the pegs have broken off. I tried using the Aileen’s glue, but it isn’t the right kind of adhesive. I also need to replace the grill cloth on one frame. Since I have to do one, I will probably do both so that they will match. I may even build new frames – we’ll see. I also need to come up with new woofer gaskets – any suggestions?
A few thoughts:
Aileen’s glue works just great!
Turpentine and linseed oil is very simple, cheap and easy to apply as a speaker finish.
MEK is great stuff for removing old surround from the frame and cone. However, it is very powerful and will etch plastic.
Gordon W is a great supplier. I had a problem with the first dustcap and he immidiately sent a replacement. The surrounds worked great.
A few thoughts:
