Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Vintage Solid State
We appreciate your help
in keeping this site going.
FORUM RULES
Reply
Thread Tools Display Modes
  #1
Old 07-09-2004, 10:48 PM
Polar Bear's Avatar
Polar Bear Polar Bear is offline
Banned
Blown Left Channel on Pioneer SX-727
Hey guys, I just had to share this with you guys and I cut and past this from another audio group, and couldn't believe the advice was given to this guy who was asking if his SX-727 was salvageable, read on....
Polar Bear
_______________________________
This might not be the best place to post this thread, but i've read enough posts here to see that a good portion of the membership exhibit excellent core knowledge. Any thoughts would be appreciated.
I have a (1973) Pioneer SX-727 that seems to have lost its left channel. On the evening of "burn-out" the system started producing the characteristic scent of burning electronics. The unit still produced sound but after a bit of time (after the smell dissipated) i noticed the loss of the left channel (not easily recognizable as this set-up has four speakers oriented kitty-corner in a square room). I unplugged the right channel speaker outputs -- and turned the balance all the way over to "L" -- and the resultant sound was distorted, scratchy, and all fuzzed out beyond recognition. Switching speaker outputs I see that this holds true on all of my left channel outs; "A" "B" and "C".
I'm only guessing here, but are there two separate amps that power each channel, and if so, can they readily be replaced. Or, could my loss of channel be attributed to some other entity.
What do you think?
J. Vigne
Unregistered guest
Posted on Tuesday, June 08, 2004 - 10:19 pm:
After 30 years of use the internal components have simply worn out. Most likely the values of a few bias resistors have drifted and the capacitors are no longer capacitating (yeah, I made that up, but the caps are shot). When this happens the output transistors fry. And if I remember correctly the 737 had what were caled Darlington Block IC (integrated circuit) outputs. Personally, I can't believe it has lasted this long.
This is not what you want to hear (you know what's coming already, don't you?) but at this point in time it is not worth fixing. You will find it very difficult if not impossible to find a shop that has not culled the schematic for this reciever from their files years ago. No schematic, no fix. Bias levels cannot be set properly and values of common components like resistors and caps can't be guessed at. More than likely when the smoke appeared it meant not only fried outputs but more than likely a fried circuit board. There is no way to replace that now days.
If I were you, I would thank the Pioneer for 30 years of service and head out to buy a new unit. If I remember correctly once again, that was only 35 watts per channel and it sold for less than $299 in 1973-4. That means it has cost $10 per year to own this reciever. It is time to retire the SX-737. If you shop carefully you will be suprised at what you can get for your money today. If cost is important look to the used market to find a good value.
John A.
Gold Member
Username: John_a
Post Number: 1345
Posted on Wednesday, June 09, 2004 - 01:06 am:
J. Vigne is spot-on as usual. Let me just add that there ARE makes where you could repair a 1973 amp and it would be good as new. As J. says, though, one component failure (electrolytic capacitors do dry out and eventually fail) and it can take a whole load of other things with it. You may need to be quite skilled to diagnose the problem, it is unlikely to be simple. That means heavy labour costs. Probably even skilled repairers would advise you to write it off.
If you are thinking of something new to last another 30 years....
Chris Hackbardt
New member
Username: Suspecterrain
Woodland , MI
US
Post Number: 3
Posted on Wednesday, June 09, 2004 - 09:29 am:
Thanks both,
I didn't think it smelled like there'd be any simple fixes. And yes, i'm very thankful for the length of time this unit has served me (10 years).
I would like to add a minor correction to your comments, J. Vinge: This was the 727, not the 737 -- this one retailed for $399 back in '73 and packed 40 watts per channel. In it's death i would hate if people thought less of my stereo than what it actually deserved.
For what it's worth, i just tagged a model SX-828 (same year, flagship model) for a cool $30 on ebay -- know i'll be flexing 60 watts per channel! That is, if the thing isn't DOA.
Thanks again for the comments - i knew somebody could give me some inferences on what a post mortem on this old girl might uncover.
  #2
Old 07-10-2004, 04:19 AM
EchoWars's Avatar
EchoWars EchoWars is offline
Lee Ho Fook's or Bust
Idiots....
Where was this posted?
With that attitude, virtually 3/4 of AK would be listening to BPC.
__________________
"We
Of the night
Will know
Many things
Of which
You sleepers
Have never
Dreamed" --Bessie Haley
  #3
Old 07-10-2004, 04:27 AM
Polar Bear's Avatar
Banned
Hey there EchoWars......try this link.
Get them straighten out.
Polar Bear
http://forum.ecoustics.com/
  #4
Old 07-10-2004, 02:13 PM
EchoWars's Avatar
Quote:
Closed: New threads not accepted on this page
Threads are closed after less than a month. 'F' it, let em' wallow in their stupidity.
__________________
"We
Of the night
Will know
Many things
Of which
You sleepers
Have never
  #5
Old 07-10-2004, 02:26 PM
Polar Bear's Avatar
Banned
Makes us AK members appricate this group that much more after reading articles like that since we love our vintage gear rather then most folks off the street.
Polar Bear
Audiokarma
  #6
Old 07-10-2004, 11:07 PM
SolderIron SolderIron is offline
AK Member
$30+30 shipping arn't bad if it works. Doubt he can get anybody to fix the old one for less.
  #7
Old 07-11-2004, 01:12 AM
glen65's Avatar
glen65 glen65 is offline
Member
Re: Blown Left Channel on Pioneer SX-727
Quote:
Polar Bear
What do you think?
J. Vigne
Unregistered guest
John A.
Gold Member
Username: John_a
Post Number: 1345
what a bunch of bullshite.
  #8
Old 07-11-2004, 01:56 AM
Polar Bear's Avatar
Banned
Re: Re: Blown Left Channel on Pioneer SX-727
Hey dude, you've miss-spelled " Bullshit "
Quote:
  #9
Old 07-11-2004, 02:33 AM
glen65's Avatar
Member
Guess I should tell the next person who brings
me a vintage receiver to $hit can it because of a
few dead caps.
  #10
Old 07-11-2004, 02:38 AM
Polar Bear's Avatar
Banned
Yeah...it's hard to believe there's people still think that way about vintage gear.
Flood me with 70's vintage gear verus today's A/V plastic throw aways.
few dead caps.
Audiokarma
  #11
Old 07-11-2004, 03:22 AM
glen65's Avatar
Member
Something that pisses me off is the way manufacturers
are throwing around wattage figures any more.
they will stamp 500 watts on the box in 4 inch
print. Then define what it all means in print
you almost need a magnifying see if at all.
Then top it all off with piss poor build quality.
And people wonder why some just want to keep
their old equipment. Duh.. “Gee Wiz I just can’t imagine
why”.
  #12
Old 01-03-2008, 12:36 PM
suspecterrai's Avatar
suspecterrai suspecterrai is offline
Suspecterrain
Help me, I'm the Sucka!
Alright. It's me - i'm the nincompoop who has the problem -- I just came across this website whilst purusing the web for my original post. It is a bunch of garbage that the original thread is dead (http://forum.ecoustics.com/bbs/messages/1/51433.html) as i'd really like to give the idiot with the crap advise a real piece of my mind - or better yet, a swift kick in the pants!
Well, i did pitch that unit (after I striped it of assorted parts) and subsequently bought another SX-727.
...Looks like i should get the "caps" replaced, right off, eh? What should i expect to pay, $100? Any other thoughts?
  #13
Old 01-03-2008, 05:06 PM
Suspecterrain
I little digging around found an associated thread that puts the number at a couple hundred bucks - now if i can just find a reputable shoppe to take my unit to...
http://www.audiokarma.org/forums/sho...d.php?t=140017
  #14
Old 01-03-2008, 05:12 PM
markthefixer's Avatar
markthefixer markthefixer is offline
Tooluser
Yes, WELCOME to AK................
Come on over to the Pioneer forum, and tell us what is wrong with your currently sick unit!!
If you do the labor yourself, I would (just off the top of my head) expect that you could get the caps for under 20 bucks, maybe even shipped for that.
Usually to get a receiver back from the ravages of old age, the contacts are cleaned with deoxit, the pots are deoxited and faderlubed, and the electrolytic caps replaced. Sometimes remounting the power transistors with fresh thermal compound / grease is a good precaution. Then the bias and offsets for the power amp are set back to spec. Of course a good physical cleaning goes without saying... For Pioneers, checking / resoldering the heat stressed solder joints is always a wise investment of time. From that point onwards it depends upon the original unit. YMMV
__________________
Nothing is ever completely fool proof, because fools are so ingenious.
  #15
Old 01-03-2008, 05:17 PM
Tooluser
Well, you can always ship it to our Wizard EchoWars (Kansas City). You will get back a unit in tip top shape.
Otherwise there are a lot of choices in Michigan and the area, it's sort of AK's unofficial hub.
__________________
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
AudioClassics
Grant Fidelity
Turntable Depot
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
Audio Atlanta
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
McIntosh Cabinets
Yesterday's Audio
Zebra Cables
Radio X
Venus HI-FI
vancouver audio speaker clinic
MCM Electronics
Politicalchat.org
Videokarma.org
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
©Copyright 2002-2009 AudioKarma.org, All rights reserved.
